Question about Canon imageRUNNER 210S Copier
I have a problem with copier canon ir 1600 it shows E000 as system error when i switching on, help me to solve this
  • 148 Answers
A E000 indicates a problem with the fuser heater
The fuser rollers (top and bottom ) have heat lamps in the core
there is a thing called a thermister ( temperature sensor) that could be bad
If you are handy you could (by all means unplug the power form the copier to the wall or power source)
remove the cover protecting the heat lamps and remove the lamPs( they are long like a 13 inch straw( YOU WILL NEED A SMALL PHILLIPS SCREW DRIVER, PLIARS
do not touch the glass part with your fingers
inspet the filament to see if it is burned out
if so call a copier dealer ( cannon dealer may or may not have them and may not sell to you)
I usually call a competitor and see if they can get me one or will install it
Worst case you can call and get estimates on what they would charge to fix it
Good luck
Posted on Jan 01, 2009
  • Steve Archer Jan 01, 2009
    One other suggestion before removing fuser lamps after unpluging then plugging in and turning machine on press * and # at the same time to see if this will reset the code
System Error E000
press *28*, select copier, err,clear,ok. switch off the copier and switch on after 60secs. hope it works.
Nov 28, 2012 | Canon imageRUNNER 1600 Laser Printer
I get an Error E000 on IR 1600
hi you have problem with fuser unit may be some time this problem came when yours copier is 220v and you have put in 110v if u dont then u have problen in fuser unit may be broken lamp or thermal fuse thanks
May 12, 2010 | Canon imageRUNNER 2010F Copier
Please, i don t know to much about copier i have a canon ir 1600 when i powor it after sometime is displaying system error E000 sos please. zakaria
i dont know more abotu copier when the copier on the paper jam error wil displayed how to solve the problem the jam Error Code :0360-0-367596
Jan 06, 2009 | Canon imageRUNNER 2000 Copier
Error code E OOO in canon iR 1600
The product support page is here:
Press */special function, #/ID. It will show "SSW" Select 12. Clear" with left error and press OK. Select "All" with left arrow and press OK. It will say Please Wait. Turn the copier off for five minutes and then power it back on.
Hit * and then # again. Go to the printer reset function. Hit OK. Turn it off again for five minutes and come back to it.
Dec 06, 2008 | Office Equipment & Supplies
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
Entering service mode: press "aditional function" and after "#(ID)"
Jul 16, 2008 | Canon ImageRunner 1600 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Technical suport
I have e000 message on my machine IR 1600
Jan 24, 2008 | Canon imageRUNNER 2000 Copier
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageRUNNER 210S Copier Logo
79 people viewed this question
old marine
old marine
