Question about Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC
To Download MSI file of Office Xp
I need to Download PROPLUS.MSI file of Office Xp. some conversion need this file. So please help me how to get the file from net.
  • ravi_madhuri Mar 11, 2009
    yes
  • pa_joshi Apr 23, 2009
    I need to install on my computor file PROPLUS.MSI.
    How do i free download it ?
  • 827 Answers
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
I am wondering if you went to Help? And did you click the arrows to see more options? It is there you will see the Detect and Repair. Once you click on that, it should find and/or repair the missing file(s).
If that didn't work, you could always uninstall and reinstall MS Office.
Hope this helps
Chris (ziraffa)
Posted on Jan 01, 2009
Setup cannot find proplus.ww owow64ww.cab
How to fix - Setup cannot find ProPlus.WW\ProPsWW2.cab
When you receive the error "Setup cannot find ProPlus.WW\ProPsWW2.cab" it might mean the MD5 checksum the install was expecting and the one on the actual file do not match. Here's how I fixed the issue.
First let me explain in simple terms what the MD5 is. MD5 is an algorithm that is used to verify data integrity. If anything in the file changes the MD5 will also change so it's a way for the program to check the integrity of the file.
The MD5 file is kept in the setup file of the proplus.ww folder. Open it with notepad and find the section that looks similar to the following **the numbers after "MD5 =" is what you need to be concerned with. Also remember that your numbers may differ. **
<LocalCache DownloadCode="{90140000-0011-0000-0000-0000000FF1CE}" SkuComponentDirectory="ProPlus.WW">
<File Id="Office64WW.xml" MD5="899A7D743D01852EBD036B465D1EF181" Size="4685" RelativeCachePath="Office64WW.xml" RelativeSourcePath="Office64WW.xml"/>
<File Id="Office64WW.msi" MD5="43B44C38BE513D9589ECAC7129DDC7C3" Size="3025408" RelativeCachePath="Office64WW.msi" RelativeSourcePath="Office64WW.msi"/>
<File Id="OWOW64WW.cab" MD5="E1E97F01F4292B89953204557A043C7D" Size="23865400" RelativeCachePath="OWOW64WW.cab" RelativeSourcePath="OWOW64WW.cab"/>
<File Id="ProPlusWW.xml" MD5="146CA2B8E1559F81E8DF6A3AED949E2A" Size="17252" RelativeCachePath="ProPlusWW.xml" RelativeSourcePath="ProPlusWW.xml"/>
<File Id="ProPlusWW.msi" MD5="F7DCCD578605F72AEEED775C9EB40AB8" Size="24809472" RelativeCachePath="ProPlusWW.msi" RelativeSourcePath="ProPlusWW.msi"/>
<File Id="ProPsWW.cab" MD5="3EA469E81A6064AE4BEFE4A9ACF36A9D" Size="149278843" RelativeCachePath="ProPsWW.cab" RelativeSourcePath="ProPsWW.cab"/>
<File Id="ProPsWW2.cab" MD5="86BEB0B6A2E76E95E580615185C06B04" Size="197934115" RelativeCachePath="ProPsWW2.cab" RelativeSourcePath="ProPsWW2.cab"/>
<File Id="setup.exe" MD5="4D92F518527353C0DB88A70FDDCFD390" Size="1100664" RelativeCachePath="setup.exe" RelativeSourcePath="..\setup.exe"/>
<File Id="osetup.dll" MD5="FCC38158C5D62A39E1BA79A29D532240" Size="5789544" RelativeCachePath="osetup.dll" RelativeSourcePath="osetup.dll"/>
<File Id="ose.exe" MD5="9D10F99A6712E28F8ACD5641E3A7EA6B" Size="149352" RelativeCachePath="ose.exe" RelativeSourcePath="ose.exe"/>
<File Id="pkeyconfig-office.xrm-ms" MD5="3DCFF1DCDEB1B837EC8F13351C8A92AC" Size="715834" RelativeCachePath="pkeyconfig-office.xrm-ms" RelativeSourcePath="pkeyconfig-office.xrm-ms"/>
<File Id="PidGenX.dll" MD5="7F120AAD20ECAE1EA421083F26611519" Size="1248016" RelativeCachePath="PidGenX.dll" RelativeSourcePath="PidGenX.dll"/>
<File Id="Setup.xml" MD5="" Size="" RelativeCachePath="Setup.xml" RelativeSourcePath="Setup.xml"/>
</LocalCache>
Next you will need to download and install an MD5 checker. I'll leave the process of how to use the MD5 to you to learn but it's pretty simple.
Next run the MD5 checker on the file/s that produce the errors during install. *there may be more than one*
Now there are 2 ways to work around this - If the MD5 on the checker did not match the MD5 in the file it probably means the file is corrupted so your best bet is to download the software again or get another disk.
Another less recommended way is to copy/paste the MD5 from the checker into the file (remember to make a backup of your setup file before) then save it and run the install again. This fools the installation process into verifying that your installation files are all OK.
Good luck!!
Jan 06, 2013 | Microsoft Office Professional 2010
When i install ms office 2007 , after some installation there is a prob to proplus/ww some thing and instslation hangs . what can i do?
If you have a usable activation key for Office you can re-download the entire office 2007 package from C'Net.
For Office 2007 Enterprise: http://download.cnet.com/Microsoft-Office-Enterprise-2007-Trial-Version/3000-18483_4-10742067.html
For Office 2007 Standard: http://download.cnet.com/Microsoft-Office-Standard/3000-18483_4-10651636.html?tag=mncol;4
For Office 2007 Home and Student: http://download.cnet.com/Microsoft-Office-Home-amp-Student/3000-18483_4-10704798.html
Once you download and install there will be an option for activation using your existing activation key.
If this doesn't solve your problem you may be having other issues with Windows or your hardware which would require looking at the exact error within the Event Log (Eventvwr.exe) that will explain what part of the ProPlus.cab file couldn't be copied/installed.
Hope this helps!
Mar 02, 2011 | Computers & Internet
Microsoft word files not opening. require PROPLUS.MSI
read this article:
http://office.microsoft.com/en-us/help/locate-missing-msi-files-HA001118572.aspx
Feb 18, 2011 | Microsoft Windows XP Home Edition
1706 need PROPLUS.MSI file fix/patch to run xp pro
I am not sure what exactly you need.
I suppose PROPLUS.MSI file is a Microsoft Installation Pack for MSOffice XP.
Incase you have a CD for Office XP and that particular file is corrup, you can download the same from the following link:
http://brianmedavoy.com/Office%20XP/Proplus.msi
Similarly you can download all the files of the Office XP disk from this link:
If you need any further help pls feel free to get back to me.
If this is what you were looking for
Please do not forget to give your feedback and say thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
I am having problem opening my microsoft excel files.
Is Office installed or not? Here is a free Excel viewer from Microsoft if Office is not yet installed: http://www.microsoft.com/downloads/details.aspx?FamilyID=c8378bf4-996c-4569-b547-75edbd03aaf0&displaylang=EN Post back if you still need assistance. Steve Medley
Dec 14, 2008 | Microsoft Windows XP Professional With...
Uninstalled office 2007 trial version and now computer doesn't work
if u had office installed it should be in your C:\Program Files\Microsoft Office\Office folder.
also check this.
One user succeeded by renaming mso2002.dll to proplus.msi http://www.msfn.org/board/index.php?s=4bafe39c4910c1204225d07010b53bea&showtopic=9804&st=10&#entry81250
Let me know what happens.
May 01, 2008 | Microsoft Office XP Professional Special...
Microsoftofficexp professionalfrontpage
I need to download 'PROPLUS.MSI' in Microsoft Office XP Professional with Front Page, because it doesn't work recently.
Mar 09, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC Logo
3,440 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
