Question about Dell Latitude D600 Notebook
D600 bettery charging probleb
I have d600 laptop all the laptop working properly but charging problem when i see the setup where bettery indicate idle and bettery led is 4 time blink orange and 1 time green.pls help me i slove this problem
My computer can not work and charg battery.
Posted on Jul 09, 2009
Hi, My Packet bell laptop wont accept power from the charger while the indicator on the charger shows that it is on and power is flowing through,the bettery was cheked and it looks fine and correctly...
Most likely the battery has reached the end of its usable life.
You'll need to buy a replacement battery and properly recycle the old battery.
Had you posted the model number of your laptop, I would have provided you with some online examples of stores that sell replacement batteries.
Dec 20, 2010 | Packard Bell Computers & Internet
In sony w300i phone is charging erro probleb. so pleas can u give some solution?
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 17, 2010 | Cell Phones
Dell d600 usb ports not working
There's only one USB port on the c600
Oct 11, 2009 | Dell Latitude D600 Notebook
Should a Dell Latitude D600 work properly with the AC adaptor only????--that is, with the battery removed?????
No, this is an indication of either of this two things:
1. Either your baatery is bad and needs replacement, or
2. The charging point of your laptop is faulty.
I would suggest that you test your laptop with a good, working battery first, if it works with it, then change your battery, but if it doesnt, get a technician to fix the charging point of your laptop for you.
Hope this helps.
Goodluck.
Oct 05, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Dell d600 battery on idle mode and hp nx6110 board hangs
The d600 battery being idle means that the battery is charged as much as it can be it may be 100% or some other amount if it is not at 100% I would say it will go bad sooner than you may think.
Oct 18, 2008 | Dell Latitude D600 Notebook
Dell D600
hi friend
did u your laptop has wifi if have then can u install proper driver if u have installed proper then go in control pannel there is last option in wireless network setup if u have wifi modem it will detact your laptop setup your wifi network
thnx using fixya
Jul 08, 2008 | Dell Latitude D600 Notebook
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
174 people viewed this question
Alun Cox
