Question about Zanussi ZBF660 Electric Single Oven
Clock someone please help how do i set the clock on my zanussi oven
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
Posted on Feb 01, 2009
SOURCE:
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
How do i set the clock?
no but if u call zanussi customer care they will send u an instruction booklett number is 08705727727 op 3 hold op 2 op 2
May 30, 2007 | Zanussi ZHF470 Electric Double Oven
Ovens
if the oven fan and light are not working, then the clock probably needs setting. if oven fan and light work, but no heat, then the problem is probably the circular element round the fan. remove the back panel of the oven and you can often (but not always) see the damage. replacement of the element is straightforward
May 06, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZBF660 Electric Single Oven Logo
1,358 people viewed this question
Top Zanussi Ovens Experts
gunfai
Level 1 Expert
David Ellis Rhea
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
