The default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If she didnt change it the default passcode is the last 4 digits of the phone number that was asssigned to the phone. If that doesnt work Verizon can unlock it. You have to go their corporate store.
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up
All Verizon phones default lock code is the last 4 digits of the cell number. If that doesn't work, then your friend must have changed it....only he knows, or if he's forgotten it, then you'll have to take to a Verizon store to unlock it.
Lock code and security code are generally two different things. If it is asking for a 4 digit lock code the default on Verizon is the last 4 digits of the cell phone number. If it is the security code try 6 zeros.
I find it hilarious that a Wiz ("LG expert") and a Guru had no idea that one can simply find the lock code by going through this simple process: Settings & Tools menu -- option 9 Phone Info -- My Number. Write down the last 4 digits of the phone number -- that's your reset code. Now go back to Settings & Tools, Option 6 Phone Settings, Option 6 Security and enter those last 4 digits. Simple. as. that.
LG VX 8300 Reset Lock Code To DefaultIf you have your phone serviced with Verizon this should work. Dial *228 then push send. You will get 3 options to choose from. 1. To program your phone. 2. To update your roaming capabilities. Can't remember 3rd option. If you choose 1st option, program your phone you will be told to hold while your phone is being programmed. When finished your phone should turn off then on again itself. Your lock code is then set to default. (last 4 digits of phone #)
