Question about LG RH266 Recorder
Not picking up clear tv reception through dvd player
Hi
I purchased a LG DVD recorder/ in South Africa model RH265. We then moved to Australia where I purchased a LG plazma 42inch tv. I have followed all the instructions from the DVD recorder user manual however I still do not pick up a clear reception of TV channels through the dvd recorder as well as not being able to pick up all the channels. I can therefore not record tv programs on the hard drive of the dvd recorder. I would appreciate any suggestions or help in solving this problem.
  • 1 more comment
  • dale_baker8 Jan 04, 2009
    I appear to have all the connections in place and can play DVD clearly, however when I try tune the DVD player using the easy menu set up - auto programming, but am anable to get clear reception and therefore can not record any tv programs.
  • dale_baker8 Jan 05, 2009
    Hi I am back on line, please could you assist with my problem posted above. I made payment yesterday and want to try solve the problem tonight. I purchased a LG DVD recorder/ in South Africa model RH265. We then moved to Australia where I purchased a LG plazma 42inch tv. I have followed all the instructions from the DVD recorder user manual however I still do not pick up a clear reception of TV channels through the dvd recorder as well as not being able to pick up all the channels. I can therefore not record tv programs on the hard drive of the dvd recorder.I have purhcased. I can pick up tv with the aerial pluged into the DVD recorder and another tv cable between the dvd player and the TV. This gives me a perfect picture. I have connected yellow, red and white cables from the dvd av out to the tv av in connections and chose the av1 option on the remote control to tune the dvd player through the auto programming option. This is where I pick up reception which appears not to be digital and is very fuzzy. Please help
  • dale_baker8 Jan 18, 2009
    please could you see my previous explanation of my problem which are fairly detailed, I have paid the required funds but have not had any further feedback from you. I would appreciate you contacting me or allowing me to call as I have had no further contact since I made payment .
    Kind regards
    Dale Baker
  • LG Master
  • 19,396 Answers
If TV is analogue, buy a sygnal booster.
TV Signal Booster
Improving an analage signal (TV),Signal Booster
Posted on Jan 20, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try to recordin diffrent medialike on a dvd+r written +R disk. Then take it out and replace with blank -R (recommend you to use rewritable(RW) DVD's). Then it would come up with new screen asking if you want to initialize disk. Answer it yes and it will take about 20 seconds. Then try to DUB from HDD to DVD again. This time it came up with the dubbing menu.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize.
Ask for clarifications
Posted on Jan 18, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 18, 2009
    The recordings you've made on the HDD are they of standard definition TV broadcasts (SDTV) or transferred from copyrighted DVD sources? If they are coy-protected they will not record, if the size of the recording exceeds the DVD's capacity it will ask for a media with greater capacity, such as a Dual-Layer DVD. Ensure that your recordings do no exceed 4.3GB and it should work okay.
  • Rylee Smith
    Try to transfer a small clip of 5 minutes standard definition TV. If that fails it's probably a faulty unit and you need to get it exchanged or repaired as it is warranty, won't cost you a penny.
  • Rylee Smith
    Try going into the OSD and see if lessening the brightness and contrast will improve the sharpness of the picture.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, the DVD being cleat indicates that the connection from the DVD recorder to the LG plasma TV is correct as you have posted. Your additional post of "not...clear reception of TV channels...not...pick up all...channels" also indicates that there is reception albeit weak/poor, still the connection is there. Based on all these, may I offer possibilities/ideas you can explore/try:
  • temporarily directly connect the coaxial cable to the LG TV instead of passing first the DVD recorder. If the reception is better, there is an issue with the recorder, if the reception is the same, there is a probable issue with the signal coming in;
  • try to connect the incoming coaxial cable to another TV and note the quality of reception, if the same, the signal from the cable is the issue, if clear, then the setup of the DVD recorder is the issue;
  • may I inquire, when you were in South Africa, were you using an aerial antenna or cable from a provider?
  • in Australia, are you using an aerial antenna or cable from a provider?
  • On most tuners (whether DVD recorder or TV) there would be in the Menu/Setup a choice between AIR/STD, CABLE or HRC. Might it be that this has to be changed to match what and how you are receiving the signal? AIR/STD would be an external aerial/antenna, CABLE would be from a provider, HRC would likewise be from a provider.
Good luck and Thank you for using FixYa.
Posted on Jan 04, 2009
  • Louie  Role
    Louie Role Jan 06, 2009
    Hi again,
    I checked the manual of an LG RH265 and it does not have a composite video out for the video/yellow RCA cable. It appears to have only SCART and component video out which are Y, Pb and Pr. Might this be the cause of "not to be digital and is very fuzzy"
    Cheers.
  • 1,512 Answers
Hi
We have the same Tv system as south africa. So the unit should still work. Have you been able to get the Tv working with its own tuner, or another TV operating from the same aerial socket. It may be a signal strength problem preventing you from getting results.
  • 1 more comment
  • Graeme Ross
    Graeme Ross Jan 04, 2009
    The LG recorder is actually a model sold in Australia also. I would be perhaps replacing out the aerial  leads that connect the unit to the wall. They are often really low quality connectors, and may have been damaged unplugging for the move. I live in Brisbane, and am happy to answer any questions you may have and help sort out the problem.
  • Graeme Ross
    Graeme Ross Jan 05, 2009
    It is possible that you are only able to tune analog stations with the DVD recorder. It does not have a digital tuner built in from what I can tell. The plasma will be tuning to digital signal. Analog is still on air in Australia at present, but will be turned off this year. You will need to get a set top digital tuner box to decode digital signals for the  LG recorder to then tune into. They can be purchased from D!ck Smith Electronics in your neighbourhood for about $50. This will solve your problem.
  • Graeme Ross
    Graeme Ross Jan 18, 2009
    Hi Dale. It is apparant that the recorder you own does not have a digital tuner built in. This is the reason for the poor pictures as I have already explained. If you go to a Harvey Norman or DickSmith electronics store, you will be able to get a digital tuner set top box to add to the unit and solve your problem. Cheers. happy at answer any questions you may have about this.
    regards
    Graeme
    (Brisbane)
  • 837 Answers
Could you give some more info? What connections are you using? Is the TV tuned to the same channel as the recorder?
What is the country code for australia - lg dvd recorder
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
Hope this information is useful to you.
Nov 27, 2010 | LG Televison & Video
LG Hdd/dvd recorder receiver system ? model lh-rh3690se, speakers ? lhs ? 36se5s, lhs36se5a, i recenty bought this player but it just keeps displaying (please wait on the dvd player), nothing shows on the...
l have active subwoofer 4 lg LH-RH3690SE DVD REC.SO I M LOOKING 4 A PLAYER /A FULL SEAT.I LOST MAIN WHAN I SENT IT BACK 2 LG BECZ OF A TECHNICAL PROBLEM.AND IT NEVER CAME BACK.IF ANY ONE HAVE A SOLUTION CONTACT ME ON 0717016643 PLZ GUYZ HALPP ME
Aug 30, 2010 | Televison & Video
LG RH277H aerial reception
relocate antenna or buy hdtv antenna. use hdmi cable for the dvd rec to tv. adjust dvd rec input source to hdmi.
Jun 12, 2017 | Televison & Video
Region code for LG1757 dvd recorder
1 open the tray in dvd mode
2 push 0 seven times.
3 it will ask you if you want to become region free just
push yes
Jaysamuel
Feb 09, 2009 | LG RH177 DVD Recorder/HDD Recorder
Region problem with LG DVD RH265
no problem! I just bought a LG RH265 and made it multi region with no problems:
on your remote-
1) press HOME
2) move to SET UP
3) scroll down to LOCK (no need to enter LOCK options)
4) press "0" seven times
5) a message will appear stating the dvd player is region free.
6) ENJOY!!!
Dec 10, 2008 | LG LST-3510A DVD Player/Receiver
LG HDD DVD RH1757 region code problem
Press 'setup' on the remote
Scroll down to the 'lock' icon
Press 0 seven times - you'll get onscreen confirmation.
Oct 21, 2008 | LG RH177 DVD Recorder/HDD Recorder
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
Change my LG DVD player to multizone
Thank you .. thank you..
I bought 4 dvd's from the states that wouldn't play in Australia changed the region and it is now playing
thank you so very much
Feb 26, 2008 | LG DV276 Recorder
Connection problems.
Must be connected by now I guess :)
Dec 14, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG RH266 Recorder Logo
257 people viewed this question
Computer Repairing
Computer Repairing
