First, you should find out if it is possible to hook up your mobile phone to a PC. Some phones support this, some older ones do not. Well, if it does, check if you got a (data)cable for your phone which makes it possible to hook up your mobile phone to your PC / laptop. If you do own it, you're half-way, because from here you need software which : A) contain drivers for Windows Drivers are needed under Windows, so Windows knows to what device it should communicate to.(*) B) build up a data-connection between your RAZR and the laptop By this, Windows can communicate with the phone (**)
(*) See this as a telephone-number to contact your mobile phone. (**) See it as the language which should be spoken, to understand each other.
Now, it's just a matter of installing the software, connecting your mobile phone to your laptop and run the program.
If the laptop even after you had it charged for full charge does not hold the charge, then it is possible that your battery needs replacement. the final test that can be done is to fully drain off the battery , use a series resistor or about 100 ohms to short and drain finally after the laptop shut off due to weak battery. Now clean up the terminals and that of the laptop terminals of the battery point. Inser back and charge it again till fully charged . repeat the process about three times and see if there is any improvement. If not there is nothing that can be done but to change with an original replacement. Hope you try and see. Good day
Hi, It denotes that USB charging is not supported by uour mobile phone. If you are using the same socket in your mobile phone for charging whcih you are using for connecting your mobile to computer then there may be USB charging option available for your phone. If you are having separate charging Jack in your phone. Then USB charging option may not be possible. Please refer your mobile phone user manual to check whether the USB charging option is available or not.
It might possibly be due to the static charge accumulated on the battery conductors. Not to worry; Please remove the battery of the Laptop and without the charger connected, you need to hold the power button to turn ON the Laptop for 1 min. This will consume all the energy from the battery conductors.
This process is called power drain.
Now connect the battery and connect the AC adapter, now try to start the computer.
I am sure this will help you turn ON the computer.
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
