Question about SanDisk Sansa e250 MP3 Player
Sansa e250 Menu won't show!!!! please help!!
When i turn on my sansa the menu won't show. If i turn it on the name SANSA shows (like always) but it won't switch to the menu. instead the name Sansa just stands there and at time the screen would go blank and then go back to the Name SANSA!!! The menu won't show!!
Please help!! my dad will kill me if my Sansa is broken!!
    President:
  • 948 Answers
Http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I hope that helps. If not, please post a comment with an update to your problem.
Posted on Jan 05, 2009
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
Can not down load voice recording to computer: Sansa 280.
You can try few simple steps like changing the USB ports, turning off & turning on the mp3 player and then reconnecting it, and then changing the USB mode on device: Menu --> Settings --> USB mode: MSC or MTP
If these don't work, try the steps here: Sansa e250 Not Detected in PC
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
I have a proplem with my sansa e250 after upgrading it. Now I can't start my sansa. The whole sansa is frozen. Just appear SanDisk logo on the screen, blue wheel lite and that's all.
I tryed several time to reset it by pressing the power on (menu) buton for more than 15 sec. It power of after that, but when I try to start it again problem persist - sansa e250 is frozen after logo of sandisk apear on the screen.
Please help me
Aug 17, 2008 | SanDisk Sansa m250 MP3 Player
Sansa e260
You need to do the following:
1. Go to recovery mode by setting the hold mode to hold ,then press record button and power/menu button.
2. Connect to computer with USB cable as per meassage on sansa
3.Download an mi4 file from http://daniel.haxx.se/sansa/mi4.html for your model
4. copy this mi4 file to the 16MB partition that appears for your sansa.
5. Disconnect then power down and on again.
Jan 17, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 does not start at all
Have you tried 'recovery mode'? 1. Lock your player and hold the record button. 2. While holding the rec. button, turn on the player. You're now in recover mode. 3. Connect it to your computer and update the firmware manually. (get the file from the sandisk website and drag it into the player drive.) 4. Turn on your player and hopefully it will work.
Jul 10, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
i know i have to charge my sansa for at least 7-8 hours before the battery will show it is full. about your other problem, i believe there is an option under the settings menu to automatically shut your sansa off. If not then you can turn off the backlight and that will save alot of battery life.
Mar 02, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't move
Try reloading the firmware. If the Sansa Updater says that you have the lastest firmware download the firmware manually and then run the software. In addition, tech support is fantastic with Sansa give them a call or e-mail. Best Regards, Keith
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
