Question about Motorola T5920 (7 Channels) 2-Way Radio
How to change the frequencies in morola T5920 2-way radio?
Just Press "menu" and then + or - . Push PTT to confirm.
Posted on Jan 01, 2009
On motormu2080d, I finally got frequency changed. It still is not receiving or sending. What do I need to do?
This one is new for me, so if you posted elsewhere, bear with me. You changed the frequency, I assume to match another radio. Now you must also change the Tone, called PL, DPL,or CODE, etc. Both frequency and tone must be EXACT. Such as Frequency 2, code 1. which is default channel 1 on UHF radios. Also be certain you are not trying to match to an RMV radio, and RMV and RMU cannot talk to each other.
Apr 15, 2015 | Radio Communications
Cp150 frequency change
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Feb 12, 2014 | Motorola Radio Communications
Change frequency
Read the radio and write your desired frequency, must see you radio band. If it is VHF the put the VHF range frequency.
Jan 07, 2014 | Motorola RDU2080d Two Way Radio
Change radio frequency to infrared frequency for the emerson MS9700
I very much doubt your Emerson unit uses radio frequency for remote control
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
May 16, 2010 | Motorola XU2100 (1 Channel) 2-Way Radio
Can i change the frequencies on my two way radios?
No, unfortunately there is nothing you can do to change the 462-467 MHz radio to do the PMR 420-450 MHz which is legal in the UK.
Here is some info concerning PMR446: http://en.wikipedia.org/wiki/PMR446
Apr 24, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Can't get Hopkinville police radio on my scanner
I know that most frequencys did change, I had the same problem when all the police went to digital, I had to put in new frequencys.
Mar 31, 2009 | Radio Shack Pro-83 Scanner
Finding a adapter pin for motorola
Hola
no creo encuentres ese adaptador, Talk about utiliza un plug stereo de 2.5 mm, el audifono que mencionas tiene dos plugs uno de 3.5 mm Mono y uno 2.5 mm stereo.
Tendras que hacerlo y cortar el cable y utilizar un plug 2.5 mm
Jan 18, 2009 | Motorola 2 Pin Adapter 2-Way Radio
Change Radio Frequency
Most radios made in American have fixed tuners and do not have a way to change frequency of the radio. If they use the same FM frequencies (88.1-108.0) then all you have to do is do a scan or seek of what is available when you get there or a new radio will be needed. There may be a way to add a EU tuner and have the original radio receive the output of it through a channel in the radio. It's the cheapest way to not have to buy a new NAV/RADIO device. It would work kind of like the hands free devices that are not hardwired do here.
Oct 18, 2008 | 2008 Subaru B9 Tribeca
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Motorola T5920 (7 Channels) 2-Way Radio Logo
102 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
