Question about Kodak EasyShare One Digital Camera
My camera doesn't want to charge
    Genius:
  • Kodak Master
  • 1,019 Answers
Sounds like a defective battery
Posted on Jan 24, 2013
SOURCE:
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
My camera wont charge, when i plug in the camera the green light will blink several time and then disapear
It's probably a worn out battery. The batteries are good for 150-300 charges. Every connect is a charge. Doesn't take long.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
Just bought a usb cord charger for my nikon coolpix s203 and its been dead fir a couple of days and I wont turn on
You left your camera on for a couple of days? I'd think your batteries are completely drained. The S203 doesn't charge batteries via the USB port. Try charging the batteries overnight using the supplied MH-63 charger.
If that doesn't do it, please reply to this post and we'll go on from there.
May 13, 2011 | Nikon Cameras
Purchased a sanyo vpc-e870 yesterday ..let t he battery charge over night & 10 hours today...will not let me get past the date & time..shuts off 30seconds after i press ok?
If you read the instructions, you MUST use the external charger that comes with the camera to charge the battery, the camera wont charge the battery. The DC jack on the camera just powers the camera from the AC adapter, but doesnt charge battery
Apr 29, 2008 | Cameras
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
