Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Excess toner How it excess toner normally removed from a leser printer?
  • fwberta Jan 05, 2009
    Dear FixY,
    Thank you for helping me to fix my problem and your solution helping me to fix my problem.
    Scholar:
  • 51 Answers
Remove the toner cartridge and go in there with a vacuum cleaner using either the crevice tool or brush attachment as appropriate. This will leave a nasty black residue on your brush. If you have a compressor you can take it outside and blow it out, but keep the pressure relatively low.
Posted on Jan 01, 2009
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Can I reuse excess toner from printer cartridge?
It can be rescued, but the trouble and mess that you will endure is often not worth the challenge. Send the cartridge in for recycling and score some environmental friendly karma instead. Most office supply stores will accept them.
Nov 30, 2013 | HP Office Equipment & Supplies
Printer that priints dirty work
This is caused by a dirty photo drum that has a worn cleaning blade that removes the excess toner from the photo drum.
Remove the printer toner cartridge and use a soft cloth to wipe the photo drum clean of toner particles. Then insert the toner cartridge back into the printer.
Jan 19, 2012 | IBM Infoprint 1412 Laser Printer
I need to clean out my Laser printer - OKI OL 400EX
I replenished the empty toner cartridge using the contents of a reduced price (from PCWorld) cx-OKI400l-is cartridge. For this you need a steady hand and a very small, very shiny stainless steel funnel. These are available from a good kitchenware shop. There is a removable cap to the cartridges. I understand one should only use the Toner from a cartridge by the same manufacturer as the printer. My old OKI OL400ex is now working again. I still don't have the answer to: Where does the excess Toner go? Does it fill up the printer drum? Michael UK
Jan 22, 2010 | Office Equipment & Supplies
At times i get a message 14 no toner cart and then i am unable to make prints
No Toner then it prints again..
This could be lower toner, a generic toner cartridge will sometimes produce this, or dirty contacts where the cartridge lays in machine.
Look at the toner cartridge, where you see shiny silver or bronze, clean excess toner off, also in machine where toner cartridge lays, clean all excess toner out.
Oct 03, 2009 | HP LaserJet 4 plus Printer
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
Excess toner after ?overfilling cartridge w/ bulk toner
Did you refill the toner yourself or put a new one in or.......
Jan 01, 2009 | Dell 3000cn Color Laser Printer
Toner dumping
check under the drum, if there is excess toner there it is most likely coming from the drum unit or the cleaning unit, this is a unit that is on the drum and is supposed to remove any excess toner and dump it into a waste container. it may be full or blocked
Dec 18, 2008 | Sharp AR-M208N Copier
HP 3055 Laser Printer. How Do I clear?
open the printer remove toner cartage and see inside the any paper are jamed in printer remove the paper and if the problem is not solved the contact me i will told you what to do
Jul 11, 2008 | HP LaserJet 3055 All-In-One Printer
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
52 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
