SIP 195 MIG welder doesnt work
I was welding when the welder stopped. Fan still works, power switch lights up but no wire feed or gas released.
Sounds like your welder has over heated and the Thermostat has come on
wait for 10 minutes and then try again
If that does not work fit a new PCB
Gilmore
Posted on Jan 03, 2009
Its called Duty Cycle you mache is rate at 10 minute intervals.
I.E. 40/100 is 4 minutes out of 10 you can constantly weld.
Posted on Jan 04, 2009
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
Wire won't feed or arc fan runns
Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
Welder running but wont feed wire etc
Try to short the trigger wire back closer to the unit or better still inside the panel somewhere. There is often a relay that is operated that allows gas to flow and power to the wire feed motor. Check where the trigger wire goes it may give you some idea. If you can identify the part you can source one and see if it worthwile repairing. Cheers
Nov 18, 2009 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Jun 26, 2009 | Welding Tools
How to control welding spatterin MIG?
different gas mixes will give different amounts of spatter, pure co2 doesnt spatter too bad, flux core spatters like crazy, and 75/25 has light spatter also
Mar 03, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
