Question about Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006)
Xbox 360 My disk loader will not shut. I want to know if this is a easy fix.
0 characters
1 Points
I have a wireless xbox 360 controller and it will work for awhile with my new xbox 360 slim. then the controller will shut off and it will say Please Reconnect the Controller. i do and 3 minutes it will do...
well its pretty much easy to tell that you got ripped off because duda your xbox is brocken now so i would return it and get your money back then buy a new one
Aug 23, 2010 | Microsoft Xbox 360 Controller
My xbox headset will not shut off when i put into a new xbox 360 wired controller
there are series of problem in xbox 360 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the xbox 360 repair guide that will help you a lot Click Here
Aug 20, 2010 | Microsoft Xbox 360 Controller
The Xbox Light doesn't turn on the Xbox 360 Wireless Controller
there are series of problem in xbox which can be solved without much technical knowledge your problem is one amoung that ........ your problem belong to that so dont worry i will give you the link to download the repair guide that will help you a lot Click Here
Jul 29, 2010 | Microsoft Xbox 360 Controller
My xbox 360 conroler is not correctly reading my mic correctly
if you are talking about the disk, (assuming you are due to lack of detailed question), use a cotton ball soaked in rubbing alcohol and gently rub across disk. hope this works!
Feb 17, 2010 | Microsoft Xbox 360 Controller
How do i fix my xbox 360 e73??
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Feb 05, 2010 | Microsoft Xbox 360 Controller
How do i fix a wired xbox 360 controller that keeps shutting off during gameplay
Sounds like a short in the wire. Idk if you are able to buy replacement wires, thats how companies get you so you have to buy a new controller
Oct 09, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wired controller glows green for 2 secs then shuts off
Microsoft software is usually very good about finding mods within their systems. Since you have repaired a wire, it might somehow think it's been modded.
Double-check your repair work, if you used a soldering iron, it could have attached to another wire -causing a short (faking a mod). If you just twisted and taped it, you might want to consider a better fix.
Aug 01, 2009 | Microsoft Xbox 360 Controller
Xbox 360 controller keeps losing connection when vibration happen
first do you have a "short" in the Controller, try another one and see if it does, also try cleaning the game disk with something like "windex", also try "checking any add on memory, you could have a "Glitch", in either of these, but try them one by one, start with the easy ones first, let me know if I can be of more help, also try disabling the the "vibration", and see if it still does it, god bless and happy 4th
Jul 05, 2009 | Microsoft Xbox 360 Controller
My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on
May 30, 2009 | Microsoft Xbox 360 Controller
Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006) Logo
14 people viewed this question
Top Microsoft PC Game Controllers Experts
Pablo Gonzalez
Level 1 Expert
Are you a Microsoft PC Game Controller Expert? Answer questions, earn points and help others
