Question about Freezers
The fridge on my fridge freezer has stopped
Lynx e-nr 4ff36l50-01
he freezer is above the fridge and is a no frost model it is 2 years old
  • 4 Answers
Most "no frost" fridge freezers have this problem. No, they dont frost where you can see them, but inside is another thing!
If the freezer is working, the problem mainly stems from the condenser fan that transfers "the cold" air to the other section.
It could be the fan has broken (can you hear it running when the freezer door is shut and you have your finger pushing the fridge door switch, go on see if the light goes out!?) if it make a funny noise, then you can be pretty sure that ice inside the unit is touching this fan, so it needs a real good defrost.
Otherwise it might be the tube/ channel that transfers the air, is also frozen solid, Again a good defrost is in order. And by this I mean a good 24 hrs, unplugged, door opened, warm room, and just left. You will be suprised how much water comes out. And if you decide to remove insulating covers to speed the process up NEVER NEVER chisel or hack away at the ice... there are always tubes hidden in the ice, and if you hit one of them,,, bye bye fridge!
Hope this helps.
Posted on Mar 30, 2009
    Sergeant:
  • 311 Answers
Just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Posted on Jan 01, 2009
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Hii have an indeset fridge freezer 2 year old freezer ok fridge not cooling
Usual problem, let it defrost properly, I mean 48 hours with doors open in warm room. It is most likely frozen up inside (its frost free! no?) inside is a different matter and they dont tell you that!
Mar 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Freezers Logo
192 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
