Question about Toshiba Satellite A100-S8111TD Notebook
Black screen Today I started my laptop (Toshiba Satellite A100 S8111TD), just like everyday. I leave the room. Someone else came in, saw the laptop on, and put it off (normal way... log off..blabla..) and she does something i never do. She folds in my laptop's screen. 2 minutes later, i noticed my laptop being off again. I try to put it back on, everything works, the laptop makes the normal '' fill in your password'' sound... but no screen.... as black as it were never on at all.... How is this possible? Can i fix this myself? Can I find a temporary solution for this untill I drag it to a specialist?
  • 1 more comment
  • Aysherah Jan 01, 2009
    Ps. I tried an external screen. It's lightens up a bit, but it stays black...
  • elijahevan Jan 01, 2009
    Toshiba Satellite A100-S4164 screen black, at first I could see something in back ground but now nothing.
  • Art Ellison
    Art Ellison May 11, 2010
    Here's what I would try: Turn it off. Remove the battery. After several minutues, put the battery back in and turn it on. What happens? If the same problem, hit the F8 key on startup and try to start in safe mode. If in safe mode, can you see the screen? If so, a system restore is in order.
How do you fix a computer that has a black screen
When you turn on your laptop and the you see the Toshiba logo start tapping F8 and it will take you to Windows Advanced Options. Select Safemode with networking. Go to Toshiba's website and install video driver if not Do a system restore to a the day before it started happening.
Hope that helps.
Jul 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Sg ram wanted for toshiba lap top 256mbs
Here are some links that could help you:
http://www.crucial.com/uk/upgrade/compatible-memory-for/Toshiba/Satellite+A100-S8111TD+(Intel+Core+Solo%2FDuo+Processors)/list.html
http://www.memoryupgrade.pro/toshiba-laptop-notebook-so-dimm-ram-satellite-satellite-a100-s8111td.html
I hope that will help you.
Mar 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
Black screen on my laptop - no any pictures - laptop is starting OK
well i would say to tack up the key bored and see of the cognation is tiet if not tion it. if it is it would be the screen. sorry for the spelling i am disleksia.
May 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
My Satallite A100/A105 Laptop computer fails to come on at all.
Remove the battery pack and power up the laptop from the mains only....then replace the power pack when the machine has booted
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
TOSHIBA A100 DRIVERS NEEDED
There are at least 85 different downloads for a Toshiba Satellite A100-S8111TD since the Operating System was not specified, pls start here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Asking for password
Try a reset by removing the battery and holding the power button for 20 seconds (must also be disconnected from power)
Nov 20, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
