Question about Samsung DLP HL-P5663W 56" TV
Dlp tv will not "fire up"
We have a Samsung 46" dlp model #hlr-4667wx. The unit is 18 months old. Powering up has, periodicaly, been "not quite right" since the unit was new. Symptom: the green lamp and timer lights come on immediately when power is turned on, warning "warble" will be very delayed (45 seconds). Sometimes the warble is heard several times before the picture appears. Occasionally, a high speed grating/vibrating sound is heard, especially after power is shut off.(color wheel?) Currently, only the green lamp light flashes on power up and the warning warble is repeated every 45 seconds or so, but no picture or sound occur. These "start attempts" can only be terminated by unplugging the unit from the wall. Other combinations of green and red blinking lights can be created by pressing and holding various buttons on the remote. Would bad colorwheel bearings cause this, or is it more likely the lamp, or something else entirely?
Hi there, your instruction manual should have a trouble shooting section, and will tell you what various warning lights are indicating (ie the Lamp/Temp lights will flash in a particular sequence), and will give you the probable cause. In some cases, it could be blocked vents (dust causing overheating/shutdown), or just the lamp failure or faulty switch (indicating loose cover).
Posted on Jul 01, 2007
    Genius:
  • 1,074 Answers
If your tv is on warranty take it back to the supplier.the problem with your tv is in the power supply there is a open regulator in that circuit along with the H .O. Transistor there is a black that feeds from the HOT to the flyback which also needs to check probably it is also open.good luck my friend
Posted on Jun 16, 2007
It doesn't have a flyback or an HOT genius. It's a DLP.
Posted on May 24, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Poping sound last night now humming with no picture,unplugged tv due to not turning on/off normaly.HLR 61" DLP
It may cause by color wheel breaking off. Do not turn it on again, it will cost you more to repair. Call service for repair. If you can do it yourself, contact me I will tell you how to replace it. I can help repairing if you live in Orange county or Sandiego.
Oct 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on 50in dlp samsung
This is caused by dust or dirt in the Optical Block. Only a good TV Tech can solve this problem.Call one for an estimate.
Aug 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
May 31, 2008 | Samsung HL-R4677W 46 in. HDTV Television
Hlp4663w color wheel
Check
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
745 people viewed this question
Jerry Greenberg
Jerry Greenberg
