Question about O2 Xda Zinc Cellular Phone
Booting Issue Not able to boot the Phone
  • 2 more comments
  • Anonymous Feb 02, 2009
    boot stuck with Windows logo.
    that's all....
    really hoping ur guide
    thanks...
  • harnoko Feb 22, 2009
    boot stuck with O2 logo.
    that's all.... and like hang
    thanks...
    my XDA stuck in O2 logo
  • ameya_wak Nov 18, 2009
    where do i get rom MarsII_G4_RM2070601_WWE_ExtV2.8.0
Load the rom MarsII_G4_RM2070601_WWE_ExtV2.8.0 or equivalent you require onto the sdcard from a pc. insert the card back into your phone. hard reset with right navigation button. PRESTO your BRICK PHONE reloads the OS and is back to being a normal windows mobile phone again.
Posted on Feb 04, 2009
Htc chacha not booting on
it sounds like a hardware issue if it started heating up a lot. i haven't heard any fail or successful root causing that. i recommend searching on how to obtain your OEM rom and find the company's program they use to flash their stock rom. it was a hard process for me on my LG LUCID years ago. had to find kdv files or convert them to that. im hoping the process wont be the same for you. you will probably have to look up what buttons to push to boot up into update or rescue mode. sorry i dont have the specific solution.
Jul 25, 2014 | HTC sealed Chacha A810e .. Factory...
My LG Shine boots up to a stage and shuts down to begin to reboot again and continues to do this without actually booting completely. It will boot to a stage without the sim card and just stop at that...
sounds like you may need to reset the phone, this may solve the loop issue, but you may loose some of the data in the phone.
reboot the phone, while in the boot up process, press 1880, then let it sit.
hope this helps.
Aug 02, 2008 | LG Cell Phones
How can my iPhone be recharged as it is not completing booting up?
You can charge the phone even when it's off. Just plug it in.
As far as not finishing boot, sometimes the phone can take a few hours to boot. It may be trying to update something. It's rare but does happen. Just wait, give it time.
Jun 12, 2014 | Apple iPhone Smartphone
We tried to put factory default in Polycom IP 331 SIP Phone.It is booting continuously and it shows the following error while booting."Error loading 0004f2329caf. cfg". All the other booting...
I answered this question for another user:
http://www.fixya.com/support/t8134583-coult_not_using_boot_server_error
This occurs when the phone is set up to load it's configuration file from a ftp or tftp server and it cannot find the file or server location. If the phone is supposed to do this, please check that the ftp or tftp service is running on the specified server. The server name or ip is specified in the setup of the phone, available when the phone is first booting up. The default username is 'Polycom' and password is '456'. If you DO NOT want your phone to get it's configuration from a network server, enter the setup area and remove the server name or IP address from the appropriate section.
Jan 04, 2011 | Polycom SoundPoint IP 331 IP Phone
IPHONE APPLE 2G BOOTING PBLM
Looks like the software image you downloaded from Apple could be corrupted?
Try launching I Tunes on PC without I phone connected. Then make sure I Phone is switched off. Now hold down the home key (square at bottom of screen) Whilst still holding home key plug in your I Phone usb lead. I Tunes should identify you I Phone after few seconds and prompt " detected I Phone in recovery mode" (or similar) it should then prompt 'yes' or 'no' to do recovery. Select yes and let it start. This should resolve this issue as it did on my 3G version.
If still no luck search FAQ's section on www.apple.com
Hope that works/helps?
Mar 21, 2010 | Apple iPhone 3G
Acer extensa 5620 p[owers up to boot stops then reboots three times then stops blank screen through out procedure changed hard drive to no effect.?
You boot files could be damaged. Try booting up in Safe mode. To boot in to Safe Mode. Press the F8 key while booting up and you will get a list of booting options. Choose the Safe mode. If you are able to boot up in Safe mode, then the next normal boot should solve the issue.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Dvd/cd is corrupt
Please specify the issue,if it is with disk or with the ROM.
Assuming from my side that the issue is with ROM please check it with any bootable(operating system) disk whether it is booting or not.
If not booting with disk this is an issue with the drive and it needs to be changed.
If booting with disk then please go to device manager and uninstall DVD/CD rom drive and restart the notebook.
Nov 25, 2009 | ASUS Computers & Internet
Computer is slow while booting
So many resion for system slowness,firsly depends on your system configuration,
booting depends upon your system RAM,how much RAM you user in system,min 1GB RAM require for smoth booting.second one is overload (tmp,recent,temparary internet files,cooks),delete all the files and restart the system.
check it issue will be fix,otherwise there was a problem with OS.
backup all the C drive data on anohter drive and reinstall OS in C drive.
Surly issue will be fix.
Thanks,
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
System Booting Problem
ITS EITHER A HARD DRIVE OR A MEMORY ISSUE
Oct 15, 2007 | Computers & Internet
O2 Xda Zinc Cellular Phone Logo
451 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
