Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV not powering up
The power light will flash 3x's then go out on powering on. I here something clicking but cannot pin point what it is. I have done everything suggested, but no luck. If you know anything else let me know.
I had this same problem. Took it in the replaced the ssb (Small Signal Board) and now it works like a champ.
Posted on Aug 02, 2007
  • 1,074 Answers
Have your tv checked by a tech your problem is in the power supply or related circuit.check your regulator,along with some caps the microchip.good luck
Posted on Jul 22, 2007
  • Henry  Thomas
    Henry Thomas Jul 22, 2007
    some times with these tvs you will have to replace the main board.
TV Not turning on
You can be pretty sure something's wrong with the power board. Defective capacitors may "look" OK but aren't. It could be helpful to lay your hands on a schematic.
Jan 02, 2014 | Televison & Video
I have no power to my 40 inch panasonic plasma tv. there is no red or green light
hi, no power has to do with your tv,s power supply, the trouble may be as small as a fuse or it may be the power supply needs replacing, this is your best bet, I would check that part first, if you had blinks or lights flashing then your problem would be with the other boards if your attempting to fix this set yourself it is dangerous voltages inside and you will need a service manual for trouble shooting, once you replace the power supply if something else dosent work then you will have flashing lights that will pin point the board affected. hope this helps. happy holidays
Dec 25, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Sharp Aquos 46D43U no pic no sound
I have the same problem right now and i dont understand the solution. help?
Jul 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When turning on my panasonic cinemavision tv, it makes a click sound then the power button light flashes red three times, no picture comes on the screen, any ideas what should be done?
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Feb 18, 2009 | Toshiba TP55H60 55" Rear Projection...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power light flashes 4 times
The 4 blink code usually indicates a loss of vertical deflection. Check the solder connections on the vertical IC. If the connections are OK, replace the chip as it is defective. This chip will be a small flat IC with about 1 pins or so attached to a heatsink. It will be marked LA3847 or something similar.
Keep us posted.
Jun 12, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Panasonic TV (Clicks and turns off, then red light flashes 2x until unplugged)
IC 1006 is faulty on the DG board thats for 53TW models other models it means LOW DC voltage. If you need further info please let me know.
Apr 08, 2008 | Panasonic PT-53TW53 53" Rear Projection...
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
340 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
