Question about Microsoft Windows XP Home Edition
Error during pc start
Sir,
Nowadays whenever I switch on CPU button then on monitor
a message is display that ''''new CPU installed press F1 to run setup
or F2 to start ''''.
Then i have to press F2 then OS installation starts.
I have window XP home edition with intel dual core processor.
Please help me sir regarding this matter in order to avoid this message displayed.
thank you very much
Yours faithfully
RAJNISH TIWARI
    Scholar:
  • 145 Answers
Dear Sir,
Please port details questions to help us to serve you better. The answer which I'll be providing you is based on assumption on the little data you have provided.
Press F1 during startup,in BIOS settings check whether the New processor you have installed in shown or not. I think you also need to upgraded you BIOS. Go to your motherboard manufacturer's site and there you can find the software for upgrading BIOS.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Jan 01, 2009
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
I have an IBM Think Pad type 2373. whenever I turn the computer on I get an error: 0210: Stuck Key 01 It says to press F1 to fix it, I do this and nothing happens. Can you please help me fix this?
F1 may appear as a secondary key on your computer. When the error message starts, try first pushing the 'Fn' key (near Ctrl), and then clicking the F1 button. Then you can follow your computer's instructions to fix the problem.
May 02, 2011 | Computers & Internet
AMD Phenom-II is installed in Asus M4A78LT-MLE motherboard. While system is booting showing error message -" This CPU is not supported by this model. Please check CPU QVL on Asus website" Please...
the only phenom-II cpu's it supports are the 545 and 550 socket am3 1.01ghz. if you have anything other it will not run. here is complete cpu support list here
Nov 04, 2010 | ASUS M4A78LTM LE Motherboard
When I press my power button 3 or 4 time (on off) or some time more then display show in monitor. when I press 1st time then the pc start but no display show in monitor. when I off it and then again on it...
CHANGE CMOS BATTERY OF YOUR SYSTEM IT COSTS 10 RUPEES ONLY. ERRORS WILL GONE AFTER CHANGING THIS BATTERY. SYS WILL START IN SECONDS AND F2 ERROR WILL DISAPPEAR
Mar 29, 2010 | ASUS P4PE2-X Motherboard
Can i use lcd monitors for intel 845gvsr based desktop with pentium 4 processor. Till now I was using LG CRT monitor. Now i want to buy a new LCD monitor and planning for Samsung 18.5" 933SN PLUS LCD...
Yes, this should be possible. Just check the connector behind your graphics card to see if the LCD's cable can fit into it. If not, you can obtain a simple converter to enable you connect your LCD.
All the best
Jan 10, 2010 | Intel Motherboard
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Help and support not opening
This will be a virus or hard drive problem. Run you anti virus to see if it finds anything that may be eating up your system. If doesn't find anything, then try a system repair with your recovery or operating system disc, this will fix the missing or corrupt files. If you have any issues during or after the repair then you can assume that the hard drive is going out. More that likely a sector is going bad.
Jul 02, 2008 | HP Smart Buy Notebook
NO signal error
Hi sir,
Hope this will give you ease of mind and or hints. The No Signal error screen message is normal it depends how much delay it responds to (design or default time delay) the video card down to CPU and control units. The blank screen can be resolved by turning off the screen saver(s) you have and even to BIOS mainboard setting; disable the "turn off monitor after how many seconds" or related menu, etc.. Hope you can manage to enter BIOS maiboard setup.
Best regards,
Rosener Guyano
Jan 30, 2008 | ViewSonic VP171s 17" LCD Monitor
Microsoft Windows XP Home Edition Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
