Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
Inability to use both A & B speakers at once
Behringer pmx 1000 Europower. Unfortunately, I can only "get" sound from one speaker side A connection or B connection at a time. Is this normal?; Or there a way to get both speakers to function simultaneously?
3 Suggested Answers
  • 19 Answers
SOURCE: behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Posted on Oct 03, 2008
  • 5603 Answers
SOURCE: Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Posted on Jul 28, 2009
  • 5603 Answers
SOURCE: BEHRINGER EUROPOWER pmx 1000
The voice cancellor switch basically subtracts the left and right signal because the vocalist is usually centered... The noise would likely be in an op amp associated with this feature...
Compare your circuit to a PMH1000. On that unit first thing to check is the two electrolytic caps at the left and right noise cancellor outputs.
There are a wholle bunch of resistors and IC's 48,50,37 are all involved.
Troubleshoot this one with freeze mist (ccircuit cooler). The problem should show up easily by heating and cooling.
Posted on Jun 04, 2010
Connect speaker to amp
I suggest you download the
manual at -
http://www.behringer.com/assets/ep2500_p0183_m_en.pdf
The answer to your question depends on how you want to run the unit and the manual gives very good directions.
Mar 15, 2014 | Behringer EUROPOWER EP2500 Amplifier
Speaker connections
Hello
Get into these links for details.
www.behringer.com/assets/EP2000_P0A38_M_EN.pdf
www.americanmusical.com/.../Manual/beh_EP2000_ep4000_manual
www.retrevo.com
Feb 02, 2012 | Behringer EuroPower EP2000 2Channel...
HOW DO I CONNECT 2 SPEAKERS TO THE MIXER
Unpowered (passive) speakers connect to the Speakon connectors on the back of the unit. Powered speakers or amplified ones connect to the mains output L/R connectors (1/4 inch) near the upper edge of the panel.
Oct 06, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Have Beringer Europower PMH 1000
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Mar 10, 2009 | Behringer EUROPOWER EP2500 Amplifier
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Feb 02, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
Michael Lazar
Aug 27, 2008 | Behringer EUROPOWER EP1500 Car Audio...
Car Audio & Video Logo
105 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
