Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Sagem box displays error 01
I just bought a sagem digital box but after few hours it displayed error 01 then error 09 then 00 tried to switvh off the main but didn t work,
can t turn it off it just flashes error codes
  • Anonymous Jan 23, 2009
    I have the same problem and called Sagem support phone number and nobody answered. Never buy this brand!
SOURCE: sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Posted on Jul 25, 2008
SOURCE: Sagem PVR 62160T UK
THANKS DENISE!!!!!!!!!!!!!!!!!!!!
i had same problem Er 09 nd after reading your post i pressed 0 on the remote and the Er 09 dissapeared and the think started up! WOHOO!!!!!!!!!!!
CHEERS!!!!!!!!!
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: my sagem dvr62160sl uk digital reciever wont work
Had similar error. Currys were awesome we tried a new SAGEM power supply and system works fine. Had to order one via SAGEM website approx £15 but cheaper than buying a new box. Delivery approx 3 daays from France via UPS. Act now and you'll be up and running for Christmas.
Posted on Dec 05, 2009
  • 212 Answers
SOURCE: I have an error code 01 on my sagem PVR set top
Unplug the box from the mains and leave fro 15 mins. Unplug the antenna (aerial), plug back into the mains and switch on. It will show 09 error; ignor. Press ók'on the remote. The box will reset and reboot into stby. Plug antenna back in and switch on. With a bit of luck you will be able to do an automatic channel scan (refer to your manual).
Er 01 refers to a failed upgrade, so you may have corrupted firmware, which is not good.
Posted on Jan 18, 2010
SOURCE: no picture error message received
sagem freeview recorder displays error 07
Posted on Apr 04, 2010
Segam unblocking code,inchina
for your imei no. the master security code is :
2053451350
May 13, 2010 | Sagem my700X Cellular Phone
I have an error code 01 on my sagem PVR set top box. The manual says perform a programme search then doesn't indicate how. i have tried to press the menu to get the original installation but nothing...
Jan 18, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
Jul 24, 2009 | Samsung Prostar 816 Phone
Sagem dtr 6400t makes a whirring sound when you turn it on as if it is loading but nothing else happens. No screen is loaded so cant access any menus or anything
My Sagem DVR 6200T/6400T developed this problem. Initially, over a few days when I tried switching on the box via the normal button on the remote, the display would we black (no readout) but the box still made a whirring noise as if it was working and it would take about upto 15 mins for the display to come on and then I could use the remote as normal. After doing this for a couple of days the display evenutally stopped appearing, so the box would keep on making a whirring sound as if its was trying to initialise but nothing would be displayed on the readout and nothing happens if you press the handset. I tried turning it off and on at the mains plug, plugging the connections in and out of the box and television and at one point gave the box a 'smack' out of frustration. Amazingly I momentarily got a flashing error message:- either pb03 or p603 which upon looking online (for ages) apparently means an initialising error which seemed to make sense. NOTE- I do not recommend other people try 'beating up' their box. Anyway, this error never reappeared after turning the box off and on at the mains plug. After further research someone on this fixya site said try changing the Sagem adapor cable. I found an old external hard drive and the adaptor cable, which has the same input and output information as written on the Sagem AC/DC adaptor cable fitted and my sagem box now works fine again. And to think I was on the verge of paying out over £139 for a new box and amazingly all that was wrong with the old box was the cable! Points to note about using a different cable:- make sure the part that plugs into your box is the same size. Another adaptor I had rooted out from an external cd drive worked but it kept on switching the box off because the connection into the box (round plug) was slightly too small. The input should be 100-240V-50/60Hz and the output +12V=2.0A. Apologies for writing so much but because I no nothing about electrics I am trying to explain what I mean in laymens terms. I also suggest if you are in doubt, take your old cable into an electrical store like Maplins and get the advice you need about a new cable that is the same input and output as your sagem adaptor cable so that you do not plug in an AC/DC adaptor that could do further damage. AC/DC adaptors do not cost much and you may find that an universal adaptor set correctly may work.
I would like to thank the person who posted the solution because it worked for me and has saved me a lot of money.
Jul 12, 2009 | Televison & Video
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem pvr 6200T UK freeview box, display frozen.
Jul 19, 2008 | Televison & Video
Sagem pvr624ot
dont know how to say this but cant set up sagem with out code need 4 or two numder for the area i live in
Jun 14, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
197 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
