Question about Samsung Hue (SCH-r500) Cellular Phone
Samsung hue just shut off with full batt and now wont turn on
My samsung hue just all the sudden shut off on me the other day and now it wont turn completely back on. when i hit the power button the display smasung lights up and it acts like it is loading or booting up when the green progress bar is complete the phone just shuts off again, i have tried taking out the battery, plugging my phone charger in and nothing seems to help. I dont know if this is a common problem or not, the same exact thing happened to my girlfriends hue 2 months ago.. any help would be appreciated!
  • 3 more comments
  • catskill2 Jan 01, 2009
    I have the exact same problem. Guessing software corruption. Would be nice if there was a way out of this.
  • Anonymous Jan 15, 2009
    same problem... any ideas?
  • Anonymous Jan 25, 2009
    I turned my phone off to go to the movie and when went to go try to turn it back on it was like it was loading and it wont stop i have tried everything.......And i just got it at christmas
  • lady-jeet Feb 04, 2009
    My Hue turned off then back on it says --Download started--Emergency @ USB_ISR then Image Innvalid Next it guves my Bootblock Version
  • Mrsgman Mar 08, 2009
    I have had the similar thing happen. My phone powered down on its own, I was thinking maybe the battery was dead. I plugged it into the wall charger and now can't get it to power back up. The Samsung sign comes up and the power bar scrolls, but this window keeps coming up. I did get the message Emergency USB_ISR Bootlock Version: r500_bb:AK13.1 one time when I was trying to turn it on. I called Altell and they said it probably was software corruption. I need to take it into the store to see if the can do anything. I hadn't had any troubles with it before now. I purchased my phone in August also. I am wondering why so many troubles with the Smasung Hue purchased around this time.
  • 4 Answers
Same issue I have. Software corrupted?
Posted on Jan 01, 2009
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
What do i do when the memory is full and can't be erased because it says its empty on my samsung sch r 500 cell phone
most probably the memory was already corrupted
...try to scan memory with any anti virus then if wont work replacement of memory needed :D
Apr 06, 2010 | Samsung Hue (SCH-r500) Cellular Phone
Car wont even turn over batt is good 12.45v
The Water light? you may have over heated the car, also you may have caused a crack in the engine block by driving the car after the Temp light came on, Check the Thermostat, This may have caused the Light to come on and can cause some major problems if not replaced. Good luck!
Mar 19, 2010 | 1997 Volkswagen Jetta
05 corvette push button start wont work and batt is not dead it worked fine all day then when I got home it stoped working all of a sudden. when I push it all the lights come on and so does the ignition...
YOU NEED TO GET THE VEHICLE TO THE DEALER AS THIS NOT A BUTTON PROBLEM BUT A CONTROL UNIT. YOU CAN ALSO TRY TO DISCONNECT THE BATTERY AND DO RESET . LEAVE THE BATT OFF FOR 30 MINS AND RECONNECT AGAIN.
Jul 21, 2009 | 2005 Chevrolet Corvette
Our 2003 caravan just stopped starting,we have owned this van for 4 mon no problems, only 70000 mls, all of the sudden it won't start, changed out auto safety shut down relay switch, ignition switch still...
Check the starter selenoid, check for corrosion on batt, terminals and inside the cables, tap the starter with a metalic object and try to start the car, if it starts change the starter.
Jul 10, 2009 | 2003 Dodge Caravan
Samsung Hue r500 / changing the date display
I have not found any way to change the month and day around.
Mar 09, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Alltel Samsung Hue Problem
seeing that the phone has water in it, you should take it to a mobile store and have it fully clean.....but remember water log phone work for a time then shuts down.
Maybe you have lots of steel in your home area which could be causing so little signal strength you shoudl check that out
May 30, 2008 | Samsung SGH-D900 Cellular Phone
Samsung Hue (SCH-r500) Cellular Phone Logo
450 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
