Question about HP Photosmart 2610 All-In-One InkJet Printer
HP 2610 is saying to change black ink cartridge
HP is saying to change black ink cartridge and I did with a brand new one and it still repeats this. I don't know what else to do.
My HP 2610 was having the same problem. Turns out that I was using refurbished ink cartridges. I've done it before and it was fine. However, my printer is complaining now unless I use a genuine HP cartridge. You can get them pretty cheap at WalMart.
Posted on Feb 05, 2009
  • 81 Answers
Make sure you have removed the tape from the printhead on the cartridge. If you have sone this, then you can try turning the printer off and on a couple of times and see if this helps. You may need to press the OK button
Posted on Jan 03, 2009
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information…....
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
Howdo i refill my ink cartridges
Here are two links with refill instructions.
for the black cartridge, and
for the color one.
Hope that helps!
May 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
I cannot get my new black print cartridge to align properly. I am using the HP Photosmart 2610 all-in-one device.
I bought a new ink cartridge which will print well. But the alignment still does not work for some reason. The printer screen says to "check the device instructions" whatever that means. i am willing to continue to use the printer as is unless you have a simple solution. Thanks Gerald Lord
Jul 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
New black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Sep 14, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
392 people viewed this question
Ben Johnson
