Question about Motorola Mobility RAZR V3
The buttons will not work and the phone dials its own numbers
The buttons on my phone will no longer work and it keeps dialing random numbers and the sounds on it are going off. I have tried taking the battery out and the SIM card, but when i turn it back on the problem is still there. I do not want to get a new phone without having all my contacts and all the information saved to the phone and not the SIM card. Does anyone know how to fix this?
  • 3 Answers
My phone did the same thig because it got wet during a rainy football game.
Sorry, they had to replace the phone. Call your provider and they will run you through a series of diagnostic checks. They may be able to fix it over the phone . (it never hurts to be optimisitic.)
Posted on Jan 01, 2009
Why can't I call another speed dial extension from my phone?
Number(s) to speed dial have to be programmed first.
May 16, 2018 | Lands Phones
Can not type or call
i can't get my tracfone working
Nov 29, 2013 | Huawei Ascend Ii
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
How can I set speed dial if my phone is not the main telephone
If you have a USB port on the side of the cabinet, you can program it from the maintenance console. You can also program "personal" speed dial number in the 12 feature buttons on the right side of the phone, and/or under the dial pad on certain systems. To program the buttons, press PROGRAM the button and dial the number with an access code in front (usually 9) then STORE. So, to call 555-1212 you'd dial 9555-1212 STORE. and pick up the handset and drop it back down to end programming.
If you figure out how to program numbers under the dial pad buttons 1-0 keep in mind that it overwrites the F1-F10 keys.
Carl
Sep 15, 2010 | Panasonic KX-T7730 Corded Phone
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Switching from pulse to tone.
Hi There, I had the same problem and what worked with me was by pressing the star button before the number, or if it works with u, by keeping a hard press on thre star button for 3-4 seconds
Jan 10, 2008 | Thomson GE 26925GE2 Cordless Phone
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
Motorola Mobility RAZR V3 Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
