Question about LG Studioworks 700S 17" CRT Monitor
Colour problem i have problems with the colour some of the colours are missing
  • 115 Answers
This is a problem that is associated with some electronic components inside your monitor. Also it can happen if some of the pins on monitor's data cable (that connects to CPU) are bad or the cable itself is bad. Anyway you have to go to an monitor repairing shop.
Posted on Jan 01, 2009
SAf 298DJ-CFA green colour missing
Check the solder terminals of the Green video output transistor, at the video output card. This card can be located at the neck of the CRT itself, will directly plugged on to its back of the neck. There is an other chance that this transistor to get opened. Anyway replace it, and check.
Dec 12, 2013 | Sansui DTV2760 27" TV
Toshiba error cf20
things to check...Revolver Motor No Good ( if it's got a gold coloured gear it's the old type, new type has a dark grey gear ) this has been the biggest cause of CF20 i've had. Revolver Backlash ( does it rock backwards & forwards slightly when operated by hand? ) , this can be adjusted with the screws on the revolver motor. but make sure to not end up with the revolver too tight. Teeth missing on Revolver unit. ( it only takes one or 2 missing ) Colour Dev ( s ) worn Colour Dev drive gear / clutch worn ( or bushings very tight ) Colour ATS U/S Solenoid Dirty for Colour ATS ( inside ) Spring for Colour ATS return Stretched / Incorrectly fitted / Damaged I tend to check the Motor 1st, the list could go on, but these i find to be the most common causes.
Jul 22, 2013 | Office Equipment & Supplies
Sony kv-EF29M80 blue colour missing and takes time to turn on unlike how it was before. the images are blur.what could be the problem and what solution is there for it?
Check the collector voltage of blue output transistor at its video output board, which can be located directly plugged onto the neck of the picture tube. Check for any loose solder terminals at this board.
Dec 04, 2012 | Sony KV-32FX60 TV
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
Missing colour
you will need to open the unit and have to replace the stk ic located on the main board to make the colours proper.as it will not cost u too much but proper technician is required if you yourself does not have proper technical knowledge.its risky and dangerous but not at all costly. thanks.
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Red colour missing
hello
red colour if missing from mother board then you can fix it from graphics properties of your mothrboard driver
but red may also due to monitor,there should be black colour appeaqrs on screen instead of red.
to solve this you have to take your monitor from where you have purchased
if it is in warranty or gurantee then dont take to third party
the fault in monitor may be due to
fault in monitor cable
also check that cable is not loose
try to plug the cable on cpu again
another fault is inside the monitor
also try to on monitor using detaching monitor cable from cpu,message come on monitor ,if in that message red colour appear,then monitor gun is ok
and problem is in monitor due to desoldiring
if you know about soledring than you can fix this problem yourself only if you know otherwise take it to shop from where you sold it
Nov 22, 2008 | Intel D101GGC Motherboard
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
LG Studioworks 700S 17" CRT Monitor Logo
82 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
