Question about Apple iPhone Smartphone
Iphone is disabled connect to itunes and if i do so itunes says can not connect to itunes you must unlock the passcode first.. how can i do it when my iphone is disabled??
  • 2 more comments
  • Anonymous Jan 13, 2009
    My friends locked my ipod touch by getting my code wrong and i have to connect it to itunes, when I do that, it says insert code, but I can't because my Ipod is disabled
  • Anonymous Jan 28, 2009
    my iphone is disabled it cannot connect to itunes
  • abhimore007 Jan 28, 2009
    iphone is disabled connect to itunes and if i do so itunes says can not connect to itunes you must unlock the passcode first.. how can i do it when my iphone is disabled???
  • Kathleen Bota
    Kathleen Bota May 11, 2010
    does it tell you that you need to take the passcode off the sim card?
    if that's the case, try putting your sim card in another phone, disable the password, then put it back in your iPhone. if that doesn't solve the problem, please post the exact message that the iTunes gives you when you plug in your phone.
    bru
  • 45 Answers
Turn off the phone
hold the home button while turning the phone on.
Posted on Sep 15, 2009
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
How do i unlock my iphone
You can put your iPhone into Recovery Mode to unlock it. This will allow you to restore it without needing the passcode.
Step 1. Disconnect all cables from your iPhone and turn it off.
Step 2. Press and hold the Home button and connect your iPhone to iTunes. If your iPhone does not turn on, please turn it on manually.
Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode.
Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone.
Step 5. Once the restore process is complete, you'll be prompted to setup your iPhone as if it were new. If you have an existing backup, you'll be able to load it.
Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you unlock a disabled iPhone with Recovery Mode. Therefore, please consider carefully whether you need to use this method to fix the issue.
Dec 20, 2016 | Apple iPhone Cell Phones
How to unlock my iPhone without factor reseting it please help
either remember code or can try notifying provider for assistance
Oct 22, 2016 | Cell Phones
How do i disable the passcode on a iPhone 6 plus with IOS 10.0.2.
You can't unless you do a factory reset, this wipes the phones memory clean along with the password or code.
Oct 06, 2016 | Cell Phones
How do I connect to iTunes from my disabled iPhone?
iphone is disabled connect to itunes HOW???? ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jul 26, 2012 - i have connected my phone to the computer and nothing. phone still reads disabled connect to iTunes. frustrated!!!!!!!!!!!!!!!!!!!!!!!!! iPhone 4. My Iphone 4S is disabled and says connect to Itunes but i can't as ...
Jan 26, 2014
to allow acesss please respond on your iphone, ...
Nov 27, 2013
ipad is disabled connect to itunes
Aug 11, 2013
iPhone is Disabled connect to iTunes
Mar 14, 2013
More results from discussions.apple.com
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - ... forgotten your passcode, or if a message says that your device isdisabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't sync or connect with iTunes, use ...
iPhone 4 Disabled but cant connect to iTunes to fix it ... - iFixit
Jan 06, 2016 | Cell Phones
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
Iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 28, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
443 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
