Question about Samsung YP-U2X Digital Media Player
Dead Battery After about 2 months of non use, the battery is dead and will not charge. My computer does not even think anything is plugged in. I have tried other plugs and other computers with no luck.
  • Gabe Cody May 06, 2007
    Any idea where to look for one. It is "non replaceable" according to the instructions.
Most bateries that stay dead that long loose their memeory for being charged. You might try a new battery.
Posted on May 06, 2007
SOURCE:
I stored my mercedes for 4 week and the battery is dead it is normal
Yes, it is totally normal for your Mercedes battery to go dead after 4 weeks of non use due to the onboard computers that drain on the battery. I store my Mercedes for up to 5-6 months at a time. The solution is to install a battery tender that plugs into a power outlet in your garage and this will maintain proper charge in the battery and then will shut itself off until the voltage drops below the threshold again , then will kick on and bring the battery up to full charge. Any auto parts store, ie. Napa, Auto Zone, Pep Boys, etc. carries them. Cost is approx. $35-$45 and take the average person 1/2 hour to install.
Jun 15, 2014 | 1999 Mercedes-Benz CLK
My bmw 320i 05 model wont start (no sound) and there is no dead battery sign on the dash board
If your battery is dead enough, even the dead battery indicator won't light. Take the battery to an autoparts store for a bench test/charge first before trying anything else.
Feb 19, 2013 | 2005 BMW 320i Automatic
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
My mercedes sat for 10 months while I recuperated from injuries. The battery was completely dead. Remote didn't even work. We were able to jumpstart it with battery cables but it won't keep running. Dead...
You will burn out your alternator if you keep on doing this.The alternator is not a charger. If you have a dead battery you should always charge it overnight on a charger.To keep the battery fresh all that you have to do is disconnect the terminals.Yes this is normal because the car has clocks and alarms that drain power even when the key is off. If you let the battery set to long while it is drained it will not take a charge.
Jul 06, 2010 | Mercedes-Benz C230 Cars & Trucks
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
TX IS DEAD
The T3 will appear dead until the battery has SOME charge. A totally dead battery, even though plugged into a charger, will not let the T3 turn on. You mention a previous charger problem. Could be a bad charger, or a bad battery. Check to see if the charging light is on on the T3 when you think you are charging. If it is not on, try another charger. If it is on, you may have a bad battery.
Jim
Sep 09, 2008 | Palm Tungsten T3 Handheld
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
Samsung YP-U2X Digital Media Player Logo
309 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
