Cant get my belco alpha 400 linux 2.4 online by wifi
Hi i need help i cant not get my belco alpha 400 linux 2.4 the usb wireless will not connect 2 the internet server even tho i added the network and key.please how do i get it 2 connect to the internet wirellessly?thank you
  • 4 Answers
First of all does the modem say you Internet check the LED light or directly connect your laptop to it through the Ethernet interface looks like a phone plug but wider if you do have Internet the problem is with the router. it is not syncing with the modem this should be fixed by reseting or unplugging for about ten minutes if thats does not fix the problem you may have a faulty router or a modem doesn't send the right code to your ICP why you can get LAN Internet and not wireless is one of those mysteries.
Posted on Jan 07, 2009
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this laptop to enable getting wireless connection of internet?
There's a lot of available wifi adapters out there that you can just plug into your laptop's usb port. You can try looking them up online or in computer shops.
Jul 29, 2011 | Computers & Internet
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Sep 29, 2009 | NetGear DGN2000-100NAS Router
Cant connect to the internet
Hi, Can you provide some more details:
1. Model number of wireless router?
2. Are you online when connected direclty to the wireless router using ethernet cable.
3. Operating system on the computer with the adapter WPN111.
This will help me provide an effcent resolution.
Jul 28, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Bue
Apr 14, 2009 | Compaq Evo N600c Notebook
Wifi disable
If you can see the available Wifi signals in your area then the wireless is turned on and working fine. you need an encryption key and to configure it or have it auto detect to connect to them.
Unless they are open connections with no encryption/security.
Do you have your own wireless network or are you trying to get on some one elses?
You will need your encryption to get on.
Select you connection from the list, click connect and it should prompt for a key code. enter it and it should do the rest.
Feb 03, 2009 | IPC -400
CANT GET ANY WEB PAGES 2 LOAD
If you still can't access webpages to load using different web browsers, then the problem is in your internet connection server. Also about your 2nd problem, go to this link:
How to remove linux and install windows xp
http://support.microsoft.com/kb/314458
Jan 09, 2009 | Computers & Internet
Update
im sorry but you might have to be a bit more specific. I dont think u can update a ds game. and u cant connect it to the computer. the possible putcome i gathered from that is that he wants to play his game online and trade pokemon etc. meaning u need to connect the ds to your computer wirelessly using a
-nintendo wi-fi usb connector-( a usb drive u basically plug into ur computer and gives off internet for nintendo products) or a -wireless router or modem- ( the black box that the cables go through for internet).
When your grandson plays the game and wants to go online, (i will explain how to use this using directions in the game)
1. turn on the ds and load the game
2. watch the introduction movie (shiny pokemon)
3. on the main screen where you decide to either continue, new game, or -NINTENDO WFC SETTINGS-, go to nintendo wfc settings
4.tap the blue box labelled nintendo wi-fi connection settings
5.if ur using a Wi-fi usb tap connect to wifi usb or if using wireless internet tap a blank connection square
6. follow the prompts for the wifi usb and u will be connected to the internet
7. for wireless internet, tap search for an access point
8. when it has found the wireless internet tap O.K/connect/next etc and follow the prompts
9.when thats connected return to pokemon Diamond main screen then tap new game/continue to play
10. walk to the pokemon centre and go downstairs to battle online - or go into a house in
(Jublife city?) to trade pokemon online
WOAH!! that was a lot of writing!
hope i helped plz make a comment or something if u need my help again
Sep 13, 2008 | Nintendo DS Console
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
Computers & Internet Logo
348 people viewed this question
David Payne
David Payne
