Question about Philips Magnavox 27MS343S 27" TV
My TV keeps shutting off
I lost my Remote, but I have never used it because I have a cable box.. Now My tv keeps shutting off and I don't know how to keep it on.. I hope you can help me
  • cathy Ferraro Jun 06, 2007
    I thought this was a free service.. I just want to know how to keep the TV on.. Do I need the remote control to fix it.. If I do where can a purchase it..
    You never gave me an answer or soulution for this problem..
  • 97 Answers
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Posted on Jun 09, 2007
    President:
  • 1,284 Answers
Sounds like a shut down issue. Replacing the remote control wont fix the issue if the set wont stay on even using the power button.
Posted on Jun 08, 2007
SOURCE:
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
Jan 31, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Apr 13, 2011 | Hannspree ST42DMSB 42 in. LCD TV
I lost my remote, now i cant turn tv on
  • Keep in mind, there is a power button front of set also. But, if you want to use a remote, go to remote central.com and they should be able to get you the factory remote.
  • If you are using cable box or satellite box, you should be able to use that remote for powering on the set.
  • In the back of the cable box or satellite box there will be codes to enter in the remote for that set to work with the remote. Give that a try and let me know how things turn out.... Good luck and let me know if you have any more questions or need more in depth knowledge for this repair... Have a great day...HDTV GURU JAY
Apr 06, 2011 | Mitsubishi VS-60609 60" Rear Projection...
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
Tv always turns on to channel 7
If you are using a cable box, go into the general settings on cable box, use cable remote. Go to "viewer power on", and you can chose what channel you want the tv to turn on to .
Jan 28, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
372 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
