MY SAMSUNG HARD DISK COULD NOT SUPPORT TO BE INSTALLING OPERATING SYSTEM
  • 3 Answers
(The system bios can usually be entered on boot, usually by pressing the F1, F2, F8, F10 or DEL key. Make sure you save the settings before exiting))
Enter the bios and try to change the hard drive from raid to ide
Posted on Jan 01, 2009
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
No operating system found
it mean your operating system is corrupted or your hard disk is not detected with machine
for operating system re install your operating system and if you face any trouble to installing operating system like hard disk not found or no drive.
so go to setup and check that if there showing any hard drive.
absoultly not so plug your data cable and power cable properly on your hard disk and re check now if problem is not solve yet. so now pull out your hard disk from pc and plug the both wire of power and data and now check that your hard disk is running making some noise you can feel that its running if not so replace your hard disk card and now plug it on pc it will running now and install your operating system . you can operate your pc with your old data. thanks
Jul 16, 2011 | E-Machines T1855 PC Desktop
How do I erase my hard drive on a IBM T30 and reload the operating system and drivers.
Get an install disk for the operating system you wish to install (Make sure your computer is able to handle that operating system first), then put the disk in and boot to the disk. If your computer is not set up to boot to disk first then you will have to go into the BIOS, usually F2 of F12 on boot (whatever says press to enter setup), then change the boot settings from there.
Once you are inside the installer for that Operating System, it will give you an option to erase the hard drive you are wanting to install the operating system on, and restart new. Just so you are aware, this will reformat and ERASE EVERYTHING on that hard drive, so make sure that you have anything you want saved backed up somewhere else.
Once that is done, continue installing the operating system and then your hard drive will be erased, and the operating system will be reinstalled.
If you were just looking to erase a hard drive, then you can go to my computer, then right-click the hard drive you want to erase, then click format. THIS WILL ERASE EVERYTHING!
Hope this helps!
Mar 23, 2011 | IBM ThinkPad T30 2366 Notebook
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
Computer locked on WELCOME
try to reformat your computer with the istallation disk and operating system disk.
reload everything by installing a clean copy of your OS.
if the problem still persists , iam afraid it might be a bad hard disk integrety and your hard drive will need to be replaced before you can reformat your pc
Nov 18, 2010 | Computers & Internet
My Hard disk worked on other pc other hard disk
The first way to solve your problem is to make recovery of your operating system using your operating system cd.
There you can use a variety of ways to make the recovery cd with the operating system which is the operating system patch(Reinstall windows) or you can use the command promp
fixboot and chkdsk / r on the menu on the cd repair the operating system. (If you already started to boot up from CD, this menu will appear)
If there is no other way you had to reformat the computer to solve problems.
Jun 29, 2010 | Mercury KVM266PM-U (KVM266PMUD1600)...
When i install the xp operating system after
There is problem with your hard disk. Is there any noise in the hard disk.
you should change your hard disk.
Mar 15, 2010 | Toshiba Computers & Internet
My hard disk can not boot but works as slave in d ,e, f but not
to make your hard drive bootable it must be active. To be bootable it must have an os on the drive.
Sep 14, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Barracuda 7200.7 be used with NTFS drive?
Yes, it can be used that way. Do you already have an operating system installed on your first drive?
Disk can be formatted after installing operating system on the first disk or prior to installation if you intend to install the operating system on this disk.
Jan 16, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
