Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
I have black soot on my walls from my baseboard heaters, is this hazardous or dangerous to my health?
  • 5 more comments
  • Anonymous Jan 03, 2009
    IF THREMOSTAT ACTED UP CAN OVERHEATING ALUMINUM FINS ON BASEBOARD HEATERS GIVE OFF SOOT. I HAVE RAN THE HEATER ON HI FOR 5 OR 6 HRS STRAIGHT WITHOUT ANY SOOT , HOWEVER I HAVE SOOT DAMAGE ON MY WALLS .TRYING TO UNDERSTAND WHAT HAPPENED.
  • Anonymous Jan 04, 2009
    I have soot marks on the walls abpve my electric basboard heat. Why/
  • tatebeckya Jan 04, 2009
    I have black soot marks above my electric baseboard heat. Why?
  • GerCares Jan 13, 2009
    I am noticing that my bedroom wall high up is turning all black. I have only one baseboard heater close to this area. The condo that I am living in, is over 20 years old, not sure how old the baseboard heater is. Should I just have a new one installed? This is making me nervous.....thanks!
  • kiransmayi Jan 26, 2009
    i have very black marks above my baseboard heater, also my bedroom walls are turning black. what should i do?
  • darcyron Feb 26, 2009
    I have the same problem, right above the baseboards! My mgr of the apts states it's from "burning candles" Then why is it only above the baseboard heaters???
  • snowbell Jan 19, 2012
    I live in an apartment and I see black marks above my heat vents also. I have been trying to get my manager's attention to this but she writes it off everytime saying that it is from candles. I don't burn candles in my apartment on regular basis and when I do, it is only for a little bit. Could it be carbon monoxide ? I have been sick for a while with fatigue and slight flu like symptoms.
Same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dirty air (candles burning will do it) is pulled through the heater and pushed out the top causing stains on walls.
Posted on Sep 18, 2009
    Problem Solver:
  • 16 Answers
Soot caused by burning fuels (oil, gas, wood, coal) indicates another great potential health and safety risk of exposure to carbon monoxide. Soot is carbon, and where there are carbon stains then carbon monoxide has also been present. Carbon monoxide exposure can cause flu-like symptoms. Exposure to abrupt high concentrations, or long term low concentrations, can lead to permanent health damage and even result in death.
Posted on Jan 03, 2009
Www.cadetco.com/support/ownersguides/1004.pdf
GO TO TOUBLESHOOTING UNDER SOOT
Posted on Jan 28, 2009
I have the same problem in my apt. I've been trying to figure out how to or if there is a kind of barrier to put around it to stop leaving burn marks on my walls. I want to redo my walls but I'm afraid that it will ruin them to.
As for the black soot I had to use a water base bleach mixture to use. And then paint over the soot area. Hope this is helpful. :)
Posted on Sep 03, 2010
How do you clean the soot of brick?
Posted on Jul 13, 2009
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
Black soot is on the walls & ceiling around the baseboard heaters in the rental house that I live in. What is causing this & how do I clean this off?
If these are electric base board heaters, that is probably not soot, but instead mold. Put a little bleach in a spray bottle and try spraying it right on to the black soot looking stuff and see if it will disappear. If it does, it is mold. Bleach will kill the mold.
If these are gas heaters you need to call a service man NOW. Black soot is a sign of gas burning raw and can be very dangerous. Turn them off if this is the case.
May 18, 2011 | Heating & Cooling
There is black soot on my walls and ceilings above my baseboard heaters. Is there a solution or a reason as to why this is happening? Is there a part that needs replacing? We are desperate for a solution....
In my experience soot in the house is (almost) always caused by the burning of candles. Get a CO detector if you don't already have one! You see the soot at the heaters because of the air flow they cause. There is nothing in a baseboard unit that could cause soot. Just water.
Mar 30, 2009 | Fahrenheat Electric Convector Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
There is a black "soot" coming from my radiant heater
Black soot appearing above and around electric baseboard heaters is caused by burnt hydrocarbons in the air.
The Heating element draws the cool room air from the bottom and over the element. Any excess hydrocarbons in the air become burned and are deposited on the surrounding surfaces from the warm heated air flowing up out of the heater.
The Heater is not the cause of these hydrocarbons. They come from the home / enviornment.
Some cause.
Smoking, burning Candles releases waxy hydrocarbons, carpet cleaning solutions, spray type air fresheners.
Black waxy sooty deposits are usually from burning candles.
Posted by George Patterson
Jan 13, 2009 | Fahrenheat FBE15002 Baseboard Heater
Black Soot coming from heating vents Powered by Gas
Danger..........You guys both have a problem with incomplete combustion and or a possible heat exchanger breech..carbon monoxide is a very great possibility...don't mess around with it call the fire department and force the landlord to repair it.
Nov 18, 2008 | Empire DV-215 Direct Vent Natural Gas...
Black stuff on walls
your walls are trying to burn good thing you cannot turn it down it can kill you.
Jan 03, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
5,073 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
