Question about Car Audio & Video
In audio video what does the following color pin stand for: RED, WHITE and YELLOW
    Problem Solver:
  • 7 Answers
Red= right hand speakers
White= left hand speakers
Yellow = VIDEO
there u go ;-D
Posted on Jan 01, 2009
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
The 3 colors wires that hook into my pc are yellow, red & blue, but the colors on the pc are: pink, white and blue is there a color match up?
I suspect you've got the audio and video cables mixed up.
Video inputs on monitor will be yellow for video and red/blue for audio. PC end of cable will be round and connect to your video card. Or .. you should have a cable with a 15 pin mini D on both ends or a DVB cable.
The pink, white and blue connectors on your pc are audio connections for speakers/headphones.
Google is your friend
The ... Google is your friend
Jul 07, 2009 | Acer AL1951Cs 17 inch LCD Monitor
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How do i plug a game conlone to a direct tv box?
skate,
are you reffering to a game console connecting direct to a TV screen?
1st try to check if your TV screen have a terminal jack indicating "A/V INPUT" A/V stands for Audio/video. if the screen doesn't have this, you'll be needing A/V to RF converter
2nd if your screen does have a terminal jack indicating A/V INPUT the next step you need to do is: check your game consul cable it should have a 3 RCA cable having RED/WHITE and yellow marking.
RED and WHITE cable marking stands for "AUDIO"
YELLOW cable marking stannds for "VIDEO"
connect this cable to A/V input of your screen following the color code ( yellow to yello/ red to red/ white to white) then from the screen press a button indicating "A/V" or "INPUT"
cheers,
mark
Jan 29, 2009 | Toshiba 36A50 36" TV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
