Question about Fuji FinePix A350 Digital Camera
My jx520 fujifilm camera has a white screen, what's the problem?
When plugged in to be charged, I don't see the battery charge logo, youcan't see anything to take a pic,the screen is just white.
5 Suggested Answers
SOURCE:
SOURCE: Fuji Fine Pix Z5 battery won't charge
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Posted on Sep 26, 2008
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
How do I check the battery is charging on my nv8 camera
While using the camera, you can see the battery logo on the screen.
When the logo is white, the battery is full, after a while 1/3 will be dark. little longer, 2/3 and when the battery is (almost) flat it is complete dark. Then you must stop shooting and recharge the battery.
On the end of the charging cable, the plug that goes into your camera, has an indication light.
As long as the battery iOS charged, the light will be red. When the battery is fully charged, the light will be green. But if it starts flashing, something is wrong with the battery. Or at least the charging went wrong.
When you are using the AC adopter, an orange led can come on on the cable, meaning the battery is discharged.
All to be found in the manual, page 15 and 16
Feb 25, 2014 | Samsung NV8 Digital Camera
How do i control the aperture on my fujifilm finepix jx520?
Like most point&shoot cameras, the JX520 doesn't give you much direct control over the camera. You're just supposed to point and shoot, without worrying about trivial things like aperture and shutter speed.
You can get some indirect control over the aperture by selecting an appropriate scene mode. The Portrait and Sport modes, will open up the aperture as much as it can, while the Landscape mode will tend to close it down.
Feb 10, 2013 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
My camera won't charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Nov 02, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
My phone has turned itself off,& won't turn back on, whether it is plugged in or not. Any idea why?
sounds like you need a new phone but id take it to a where ya bought it and see if a different battery fix's problem. ive had a battery that would discharge all its juice at random and had that burn up a motorola. hope this helps
Oct 26, 2012 | net10.com
Fuji jx520 wont charge
Aug 29, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
How long do you charge fujifilm JV300 camera?
Remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power outlet. The charging is complete when the light on the charger turns from orange to green.
Jun 03, 2012 | Fujifilm FinePix JV300 Digital Camera -...
My camera won't charge, i plug it into the computer throught the USB & the camera lights up like it's actually charging but after a cpl hours I took it off the USB & as soon as i cut it on it cuts...
The C1033 does NOT charge batteries. By plugging it into the computer you've actually drained the batteries faster since the camera has to spend juice communicating with the computer (even if only to say it has nothing to say). Put in a fresh set of batteries, and next time don't leave it connected to your computer.
Mar 26, 2011 | GE C1033 Digital Camera
Wont go to picture taking screen or playback menu
A lot of cameras seem to be having this issue (including myself). Eventually it got to a point where the camera doesn't even turn on properly anymore. Better take it back for repair, STAT before it ends up like mine :(
Jun 29, 2010 | Fuji FinePix J10 Digital Camera
Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Sep 17, 2008 | Fuji FinePix J10 Digital Camera
Fuji FinePix A350 Digital Camera Logo
293 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
