Question about Dell Axim X5 Pocket PC
Axim x5 sd not reading
I have a Dell Axim X5 and it's not reading the SD card. Card is SanDisk microSD/TransFlash to SD Adapter. Do I have an to get an older SD?
  • the gameboy Feb 16, 2009
    it's the same with mine, it's not the adapter... i tried that...
    it'll read CF cards...
    i'm also using micro sd's for some reason though...
    i have the same problem...
    it'll read CF cards though...
    it's not my micro SD card adapter... those both work on my wii... so it aint then...
I have a 2 gig Lexar micro sd card that works fine in my Axim x5 with a couple of SD adapters I have. However, my Dane-elec 4 gig micro sd HC won't...Not sure what the deal is but I'm told it's the HC part that causes the trouble.
Thank goodnes it has two memory card slots!
Posted on Apr 30, 2009
I would think it is having more trouble with the adapter than the actual card. It could also be the storage size of the card that is the problem as well. Try a regular 2GB SD Card and see if it works. If it does, then it is probably just the adapter.
Posted on Jan 14, 2009
I have a dell axim x5 and it connects to my pc and internet fine when its on the docking station. I just need it to connect to my wireless internet connection wirelessly....
The X5 does NOT have wireless built in. You must add a wireless card (compactflash or SD) They tend to be finicky so do a little research for one that works well with the X5 first before buying.
Apr 08, 2009 | Dell Axim X5 Pocket PC
Can't install drivers for WIFI card
I purchased a VeriFone 11 Mbps 802.11b Wireless Compact Flash Adapter card for my Axim X5. I put the disc and the wifi card in my laptop and I can get on the internet. But can't seem to get it going in the Axim. It always reads "Unrecognized Card". Tried ActiveSynce and putting the drivers on a different Flash card. No luck..
Mar 17, 2009 | Dell Axim X5 Pocket PC
Cant fit my transflash adapter to my pc
ceejay_thomas,
Does your PC have a SD slot for the transflash adapter? If not you'll still need a SD to USB adapter to plug the SD into. If you have a Sony it may not be an SD slot it may be a Memory Stick or Memory StickPro which is not the same.
randy320sgi
Jan 16, 2009 | SanDisk 2GB microSD Memory Card
Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Dec 20, 2008 | Dell Axim X5 Pocket PC
My DELL AXIM X5 CF SLOT not fuctioning
Check the pins inside the slot. I had one that bent and the cards were no longer recognized
Sep 14, 2008 | Dell Axim X5 Pocket PC
Installing San Disk Wireless Lan Card for Dell AXIM 5
Actually the reason why it's saying that is because that card is not compatible with the Dell Axim X5 because if it was you wouldn't get that response. I'm still looking for a Wi-Fi card for mine as well because I ordered the P500 Wi-Fi compact flash card from Dell then come to find out it wasn't compatible with the Axim X5, it was discontinued.
Jan 22, 2008 | Dell Axim X5 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Dell Axim X5 Pocket PC Logo
525 people viewed this question
Alun Cox
