Question about Toshiba Satellite A25-S207 Notebook
Yellow Mains Power Indicator Blinking
When I turn on power the mains power indicator lighter turns yellow and blinks. Nothing else happens. Can anybody help?
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
I Have a Panasonic HDTV 1080i. I tried to turn it on today but the power button just blinks yellow. What does that mean?
The blinking power indicator is actually identifying the ircuit which is stopping the set from working. How many times is the light blinking? Please respond to this sme post for assistance.
Sep 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Laptop won't start up
Hi, the problem of which they power on both led and on having pressed the button of power on does not spend anything, it indicates that his equipment does not ignite and probable mas is that mother has got damaged the card reason for which it does not ignite the equipment.
Jan 07, 2009 | Toshiba Satellite A15-S127 Notebook
Canon Pixma Printer trouble
hi dear
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
thanks
cropp
Mar 17, 2008 | Canon PIXMA iP1600 Printer
Toshiba Satellite A25-S207 Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
