Question about HP LaserJet 3050 All-In-One Printer
How set up the dax settings in laserjet 3050 means auto detecting of fax and sending of fax
Connet the phone connecton,
Posted on Jan 03, 2009
Why can I send a fax but cannot receive one. When the line rings, it always says no fax detected.
Ensure that telephone line connector inserted in line in port(other than telephone symbol port)
In fax settings..
select automatic in answer mode
select ring to answer as 5 rings
select ring mode as all rings(single,double & triple rings)
try for incoming fax.
Dec 17, 2015 | HP LaserJet 3050 All-In-One Printer
I can send a fax on my HP 3050 but I cannot receive a fax
Look in fax menu, to see what is the FAX RECEIVING MODE. It must be set to FAX.
pifonski
Mar 02, 2011 | HP LaserJet 3050 All-In-One Printer
Unable to send and receive fax from hp 3050 series
check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 29, 2010 | HP Color LaserJet 3500 Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
How do I set up my 3050 to get a report each time I send and receive a fax?
Press menu button printer control panel.
Select the option reports.
Selected all faxes reports and that should allow you printer the report everytine you send or recieve fax
Jun 30, 2009 | HP LaserJet 3050 All-In-One Printer
Fax procedure in laserjet 3050 model
Press the Menu button and there is option to set-up select that option and there is another option call fax set-up there will be three option.
Fax recieve set-up , Fax send set-up and all faxes set-up from these three options you can set-up fax on your printer.
Thanks and Regards
Nov 26, 2008 | HP LaserJet 3050 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
How to receive fax on my home phone
V.34 'off'
Nov 19, 2007 | HP LaserJet 3050 All-In-One Printer
Sending fax
V.34 'off'
Oct 22, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
