Question about Dryers
Error code LOC on frigidaire front load dryer
The error code LOC is on when we push any button and dryer does not start
  • Anonymous May 05, 2009
    I tried that and it didnt work for me. Any other suggestions?
  • Anonymous May 09, 2009
    LOC error on control panel.. I needed to unplug the power and reconnect to reset this error. Seems OK now.
Hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Posted on Jun 07, 2009
  • 5 more comments
  • jlhuddl Jun 07, 2009
    hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
  • adolphus Sep 09, 2011
    I depressed the OPTION & SELECT BUTTONS SIMULTANEOUSLY AND IT WORKED LIKE A CHARM. THANKS.
  • A. Nelson Oct 02, 2011
    Wow! I was worried that I was going to have to invest some money to get it fixed... After holding the two buttons for about 10 seconds it started right up! Thank you so much for your help.
  • mdennys_blan
    mdennys_blan Aug 30, 2012
    Holding both Option and Select Buttons simultaneously worked for me too.
  • edpottsnj64
    edpottsnj64 Jan 07, 2013
    as for me, i was working on the washer and pressed a button inadvertently...
  • Catrina Adams Mar 01, 2014
    Once the repair is made, i.e. door lock replaced, clearing the error code by holding both Option and Select Buttons worked for us.
  • Neil Clark
    Neil Clark Jul 02, 2017
    I `caused' my "LOC" error by inadvertently leaning against the button panel; but JUST `pulsing' the "Option" & "Select" buttons briefly won't do it; for this `Reset' to work, you HAVE TO HOLD the "Option" and "Select" buttons depressed together for AT LEAST TEN (10) seconds - any period short of that will only get you `beeps' - and the taunting "LOC" code...
This worked for me. The LOC indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Posted on Feb 17, 2009
I called Frigidaire and you need to hold SELECT and OPTION buttons for 10 seconds.
Posted on Jan 22, 2013
  • Janet Ellefson Aug 07, 2013
    Thank you so much! It works!
Unplug and wait 1minute then plug back up...resets the sytem...
Posted on Dec 04, 2010
Thank you for this info was going crazy because I don't know what it went and it worked!!!
Posted on Sep 28, 2014
Thank you. Holding the buttons for 20 sec cleared the loc error for me. I must have locked the cntrl panel when I ran Diags prior to replacing a burned element. Unfortunately I am back to the original problem, "motor runs no Heat". The element is still good but I am not getting voltage to it. I hav read other post and it appears I may have a faulty K2 Relay on the main processor board.
Posted on Apr 23, 2012
    New Friend:
I have tried holding the buttons and that does not work.
Posted on Jul 12, 2013
Dryer will not start. Has LOC error code.
Hello Luz - This is AP and I'm happy to assist you!
It appears your Frigidaire dryer console Control Lock has been activated. Without knowing your specific model number I can suggest to simply press and hold the Options and Select buttons at the same time until LOC is no longer displayed to deactivate the lock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
Mar 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
ERROR LOCK CODE: LOC
push temp button #9 and hold for three seconds LOC should clear. press the same button and it will lock controls again-but I don't know why you'd want to do that-cheersDenny
Oct 12, 2013 | Haier HWD1000
Dryer code says "loc" and
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Jul 20, 2011 | Frigidaire Electric Dryer
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
I am trying to use the dryer and an error code of LOC comes on and it won't run
The control is locked. Press and hold the OPTIONS and SELECT button at the same time for 10 seconds or until "LOC" turns off. To lock the control, press and hold OPTIONS and SELECT until "LOC" is displayed. Unplug the machine for at least 30 minutes if pressing and holding the said buttons does not unlock the control to eliminate the possibility of an electronic glitch. The control may need to be replaced if unplugging the dryer still doesn't solve the problem.
Dec 31, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Kenmore electric dryer--model 41784092500. When I press the Pause or Start button, all the lights flash and then it reads ''err'' and ''loc''. What does ''loc'' mean. Sears will not tell me. They want to...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 29, 2009 | Kenmore 84072 Electric Dryer
LOC Error Part 2
press options and select at the same time its a saftey feature
Feb 13, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
12,075 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
