D-drive causing physical/memory dump problems
Everytime I play a game which requires a disk on my D-drive/CD ROM, it will go for about 45 minutes to an hour, and then I will get a "Blue Quarter Screen of Death" (the top part of the screen will be blue and in it will be the words: "Physical Dump...something, something, etc. etc.") and then the system will completely restart. There will also be times when it will not do the physical dump thing but simply kick me out of the game and send me back to the desktop. It is not a case of insufficient RAM as these games are anywhere from 5 to 13 years old (the newest one being Disciples Gold II - which crashes anywhere from 10-45 minutes, to Starcraft and Hexen II which take closer to an hour or more) and I have more than enough RAM to load/play them. Is my D-drive/ CD ROM simply overheating? I gave it (along with the rest of the computer's innards) a very thorough cleaning with a can of air one time and it did not seem to help (much). Can someone help here please? I am about to commit cybercide on this #@%* computer!
  • 1 more comment
  • myattacksubs Jan 01, 2009
    Thanks for responding, Chiploon. It generally all happens too fast for me to notice what the words are beyond "Physical Dump," however, when I look in the event log of my computer, it states: "System rebooted from a bugcheck. The bugcheck was: 0x0000001e." (And some other extraneous information after that). According to the minidumps that got stored in my WINNT files, this has happened exactly 66 time since 5-15-08. When it happens again (and it will), I'll try and pay attention to what the rest of the words are. I do not know how to access the minidumps (they are stored in my "pictures" files - which I guess I chose to use to try and open them with) so I will not be able to report what they may say.
    Niraj, Chiploon, I have given you both a rating of "helpul" because I realize that is what you are both trying to be. (Thank you, by the way). That being said, when I went to the site to download the diagnostic, I got a "Write Error" message when I tried to download the software to two different (and new) floppy disks. Also, I have run (fully updated) AntiSpyware Bot with games both installed and uninstalled on my computer - one thing I have noticed is that whenever I attempt to do a "deep scan" of all the drives, just before it is about to finish, the system shuts down and restarts by itself. Other than that, the only thing I show after scans are cookies (which I ususally always delete). Also, I have installed RegClean and (just recently) RegCure. Whenever I run these programs, it will show the same 4-5 file path associations/references that are bad, anywhere from 27 to 44 empty registry keys which are same, and sometimes some bad DLL files or uninstall programs. I will then hit the key to "fix" these problems, it will comeback and tell me that they have indeed been "fixed," and then the next time I use them, it will simply show that the very same problems are still there!
    Question, if I should decide to simply "chuck" this computer and get a newer one, how should I go about transfering files/programs to the newer one while at the same time making sure that whatever is causing this computer to act "twitchy" does not get transfered to the newer model? That, and why, after all I've done for this ungrateful harlot of a computer, (i.e. new RAM, RegClean, RegCure, AntiSpyware Bot - $$$$$$$$$$) does it still persist in doing me like it do? Is it a hardware problem that these programs which I downloaded will see "fixed" everytime I apply them but in reality, are just returned to status quo until the next time I run any programs on it. Sorry, I know that this is a long-winded question with attending problems, but before I decide to go and "take the plunge" and shell out mega-bucks for something up-to-date, I want to know that there is nothing else which can be done.
  • Chip Loon Ng
    Chip Loon Ng May 11, 2010
    Did you notice any message from the Blue Screen error?
    Before the sentence on "Physical Dump".....what is the statement written as " 0x000007b ( xxxxxxx )?
    This is helpful to us...
    Sergeant:
  • 183 Answers
There might be several causes for it but shortest and best way to get rid off this problem is:
Test your RAM (either its corrupted or not) using testing tool
http://oca.microsoft.com/en/windiag.asp
if you RAM is fine then you being encounter of software confliction or OS corruption.
First: maker sure you Antivirus software is up to date and if it is then uninstall your all games then run full scanning then install only one game and try playing it. if still your problem does not go away then restore your OS setting back:
for that:
insert your disk (os or recovery) in dvd/cd drive (your Disk must be same one which is you have currently installed in your PC)
then
Go to star>Run then type ins "sfc /scannow" without quotes.
then let procedure to be completed by PC.
once you are done just rebood your PC.
if you don't wanna all above hassles then just install fresh OS in your sytem and once you install fresh OS you need to run auto updates for new patches and drivers.
Thanks
and
do note forget to rate answers.
Posted on Jan 01, 2009
  • 32 Answers
Hi brother,
Based on the error code, do you have Nero / Other DVDRW writing software? Try to update your nero or the DVD software.
This is a software corruption.
Update the software and let me know the status?
  • Chip Loon Ng
    Chip Loon Ng Jan 02, 2009
    Hi brother,
    1. Do not chuck away the PC yet.
    2. Reason : This is software issue.
    3. "Write Error" may refer that the diskette drive maybe faulty. Not the diskette. You may consider writing to the thumbdrive.
    4. No worries. It is not long-winded question.
    5. The software you have used is just to fix certain portions of Windows.
    6. There may be problem with the system files itself.
    7. Try Start - Run - Type in : sfc /scannow - press OK
    8. Step 7 helps to repair corrupted Windows system files.
    9. Prepare your Windows XP CD is Step 7 asks for it.
    Update us on the status.
    More important, do not throw away yet. unless it is confirmed hardware failure.
    Money is not easy to earn. :)
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
Why can't i play it
This game requires:
MINIMUM PC REQUIREMENTS
Windows 98/ME/2000/XP
Pentium II 266MHz Processor
64MB RAM
100MB Hard Disk Space
8X CD-ROM Drive
Sound Blaster 16 Sound Card
4MB Video Card
16-bit DirectX Compatible Video Card
MINIMUM MAC REQUIREMENTS
OS 8.6/OS X 10.2.6
G3 233MHz
64MB RAM
8X CD-ROM Drive
So if you don't have what it wants then it's not goin to work.
Feb 25, 2011 | Riverdeep Arthurs Pet Chase
Everytime aye go 2 play my xbox takes about 10 minutes 2 read the game and keeps askin 2 open the tray???
Normally it's the laser , but this also may be caused
by a weak or stiff spindle motor , if you open the cd rom drive
the spindle should turn freely if there is a lot of resistance
it's sizing up ,
The best remedy for this is to buy the same make drive
and swap old drives P.C. board to the new drive .
there are many source's for 360 cd rom drives. Cost 40.00
If you have any question's just comment and ill respond.
Rob
Oct 13, 2009 | Microsoft Xbox 360 Console
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Can't play game for longer than 5 minutes.
HI. the failed cleaning attempt has confirm a major issue that concerns the optical assembly. it is damaged and, it should be replaced. you can also just replace the entire CD-ROM drive as well. this is recommend.
Jul 31, 2009 | Microsoft Xbox 360 Elite Console - Black
Physical memory dump screen
This is a critical error that has occured due to a unstable core system 32 file base. this has cuased the OS to collapse. you will need to try a system restore. you may or may not be able to retrive your stored files. during the restore, some hard drive files may be deleted. this is the best way to regain stability.
In most cases, thsi is cuased by malware and virus attacks as well. you can initiate a restore by inserting the recovery disk that should have been shipped with your CPU. check in the box that it was packaged in for this recovery disk. if this disk is nto availibe, you will need to purchase a copy of you rOS. you can use this to re install the OS.
You should knwo that, when you use fresh copy of the original OS, it may wipe all stored files in this case.
May 27, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Beginning dump of physical memory
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Apr 21, 2009 | Computers & Internet
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Dell Inspiron 1200 laptop
Sounds like you have a bad Stick of ram.If you have 2 sticks remove one then try to load the operating system.If that doesnt work replace it with the other one and try to boot.If you are not sure what ram is leave a comment and I will explain.If neither work buy a new stick of ram and that should take care of your problem.Rate me if this works!GOOD LUCK!
Nov 17, 2007 | Dell Inspiron 1200 14.1 XGA LCD...
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
712 people viewed this question
David Payne
David Payne
