When i turn on my fujitsu laptop all i see is a blank screen..
The fan is working
  • 611 Answers
That fan is for the cooling the laptop
Posted on Jan 01, 2009
Fujitsu amilo Si3655 laptop screen coming blank
It Sounds Like The Problem Is Caused By Settings For A
Screen Saver You Have Enabled! If This Is Correct Then
All That Is Needed Is To Ajust The Settings Or Disable It
Completely! See The Manual For Both The Laptop And The OS For Further Details!
Apr 02, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Question about a fujitsu lifebook P5010. when i power up i have a blank/black screen although i can hear the fan running constantly. the little lcd display area next to the power button works. there are...
Hi insurancedud...
Try blowing the dust out of the laptop by using compressed air in a can or an air compressor, the compressor is the pefered choice (max air pressure 90 psi).
Blow the air into the fan discharge of the laptop, (be sure not to overspeed your fan) then blow the air into the intake of the fan.
Do this a few times until you have no more dust in your laptop.
Then see if that cooled it down, if not maybe your fan is faulty and not cooling properly.
You can also put a cooling pad with fans under the laptop to help cool , they have the laptop coolers with usb power.
Please take time to rate me thumbs up
Sep 11, 2011 | Fujitsu Computers & Internet
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
When I start up my Fujitsu Amilo Si1520, the fan starts working and nothing else happens -- screen remains blank.
Do you hear any kind of beep?
If yes, there is something wrong with your graphic adapter. If there is no beep, your MB is most probably dead
Nov 18, 2009 | Fujitsu AMILO PC Laptops
Laptop will not turn on or charge?
If the battery is fine, then the only other power source is the power adapter cord. You'll have to borrow/buy one and make sure the wattage which is on the square part of the adapter matches...if you have any questions let me know..
Apr 27, 2009 | Fujitsu AMILO PC Laptops
CPU cooling fan failure on Fujitsu Siemens Lifebook 7010D
I have opened dozens of these in the past and i have one in front of me at the moment...the easiest way to do it is. Get a blank white sheet of paper. Close your laptop and turn it face down. Remove all the screws underneath.As you remove the screws put them on the white piece of paper.So if you remove the screw from the top right then put the removed screw on the top right of the blank white page.
When you have all the screw removed the first thing to come off is the section at the on/off button (about 1nch thick covers the six buttons and has the display on it) Open the screen flat and fully extended.Remember at the back you will need to clip off on both side the grey plastic piece.(beside 2 usb connections and network port) when this section comes off you will see 2 screws underneath for the keyboard to come off...I think you will get it from here....
PS: watch out for the wireless button on the front left... this can pop off when putting it all back together....I'd say somewhere like maplin is a good place to look for one of these fans when you have it removed....best of luck
Mar 26, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Blank screen
Sometimes an easy solution to this is to turn off your laptop completely, remove the power lead from the socket and the laptop, then remove the battery, leave for a couple of minutes and then try again.
If this does not work, then you are into the realms of programming / restoring.
I hope this helps you, Chris
Oct 27, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Laptop wont function
dose it make any beeping sounds?
Jul 09, 2008 | Fujitsu AMILO PC Laptops
Computers & Internet Logo
314 people viewed this question
David Payne
David Payne
