Question about Electrical Supplies
Electrical power my electrical power safety switch keeps cutting out every time I try toget power to one section of the house. even though nothing is pluggedin. Every time I switch on the 16 amp power switch it cuts electricityto the whole house. I have now called in two electricians who havecharged me call out fees and haven't done anything to fix the problem.One suggested I may have dampneess somewhere along the circuit do youhave any suggestions
  • 4 more comments
  • thijoy Jan 02, 2009
    i don't know what gfi outlets are can you explain and thank you for taking the trouble to answer me
  • thijoy Jan 03, 2009
    hi chowmix66
    thank you for responding now that I know what they are I can tell you I do not have gfi outlets just the normal powerpoint outlets
  • thijoy Jan 04, 2009
    thanks tommy this seems the most logical solution and I am sure I will find someone who can do this for me I have had a problem with mice so this seems a likely solution. Thanks for taking the time to reply
  • Stephen Evans May 11, 2010
    Your 16 amp breaker switch my be bad. are you in the U.S.? and what name is the breaker switch?
    Gfi outlets look like a regular outlet except they have a test and reset button on them. These 2 buttons are usually in the middle between the 2 plug openings. let me know. Steve
    do you have any gfi outlets in the area of the house with no power
    Problem Solver:
  • 19 Answers
How old is your wiring? Is it cooper or Aluminiun? Important to Know. What type of electric panel is installed? If I were Your electrician I would locate the Point the panel feed reaches the Circuit( Either Lt Plug Switch Etc.) and track it from outlet to outlet through the complete cir. Youy could have damaged wires or Any number of problems, some times mice chew threw wires in wall. but tracking the circuit down step by step should be easy for a electrician, using a continuity tester. If you test intire ciruit you will find the problem impossible not to.
Posted on Jan 04, 2009
Oven works but after it has been cooking for a period it shuts the Electrical Safety Switch off. Restart & it just keeps happening.
Well it may be the breaker that the oven is connected to, overheating the switch and tripping it. Try replacing the breaker switch (main breaker box in the house rv) is the best thing, but you can place a small fan from say a old computer or laptop conected to a old cellphone charger, there both dc powered. Just make sure that when you fix it to the breaker switch you leave plenty of room for the switch to trip if it has to ' to avoid house fires'. I had to do this one year because the heater I plugged in was over loading my breaker and had to Jerry rig a old computer processor fan to keep it cool while heating that area of my house
Sep 02, 2016 | In Microwave Ovens
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
Disable all lawnmower safety switches
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
How to test lawn mower solenoid
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 16, 2016 | Garden
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
PLUGGED IN BUT WILL NOT COME ON
No...check that there is power at the wall socket...try another location...maybe the power supply is the problem.
Jul 24, 2010 | Kenmore Refrigerators
What are some the problem if transfer switch dose not transfer when genarator cut in?
If the transfer switch is wired correctly, but for some reason it fails to switch over, even though the generator starts, this will not cause a problem or a safety issue. It will simply mean that no power from the generator goes to the house, and your house will still be connected to the utility company line. The generator will continue to run, but only with enough power to keep itself running at the proper speed. It will have no load on it, which is the same thing that would happen if everything in your house was turned off.
May 20, 2010 | Zenith GE ZTX Series 200A Automatic...
I turn it on but nothing happens. I've used it a few times now and it has been fine though the last time I had to turn it off and on and couple of times before it started. Today it's dead.
The blue collector bucket has a cut off switch at the bottom. Make sure it is snapped in place. The stainless bar that runs across the top also has a cut off safety switch. Make sure it too is snapped in place.
Jan 04, 2010 | Jack Lalanne Power Juicer 250 Watts
Subwoofer makes a sound at computer startup
1.yes the electric shock can damage the subwoofer  2.some times a sudden switch off or power cut can result in for such issue . 3.for this issue just make sure that you switch on the speaker 1st before starting the PC, then switch on the PC, & while closing time also make sure you 1st switch off or shut down the PC 1st & then the speaker in last   & more ???...! do keep on writing untill then have happy computing sir...till then See you soon...!
May 24, 2009 | Altec Lansing VS2221 Computer Speakers
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Electrical Supplies Logo
112 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
