Question about HP Compaq NC6400 Business Notebook
TOSHIBA S1800-814 Does not boot nor does bios setup appears, Can anybody give me the reference to the manual to open up the laptop & isolate the problem.
After Bios Setup Laptop Cant Open The Messege isreboot computer and properly bios setupwhat can i Do?
Your question is confused. : Whad you you mean by "Can't open te Message"? If it can't boot aster bios setup probably you have a problem with bootup files. Try an application which might help yo to repair boot issues. WinPE is graeat because let's toy access theough a CD residen windowws. Thy to get one from
http://www.uploadable.ch/file/mKD6atNTMRGF/
and follow steps
Feb 09, 2015 | Toshiba Computers & Internet
How To Enter Bios Setup
When you boot up your laptop the keys to enter the BIOS is displayed briefly.
Try ESC or F1 or ESC then F1 or F2
If these do not work then
You can download the manual from this WEB site to finf the BIOS key.
http://www.manualowl.com/p/Toshiba/Satellite-C850-BT2N11/Manual/166320
May 12, 2013 | Toshiba Satellite C850-BT2N11 Laptop
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
Hallow ma names Isaiah and I would like 2 Install windows XP on my Toshiba Satellite Pro A200-EZ2204X PC Note book because I replaced the harddisk after a recent harddisk crash but everytime I boot my...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please restart the machine and tap the F12 key on the initial toshiba logo
this would reach the windows one time boot menu. You can select the cd drive as a one time boot option and initiate XP installation.
Nov 21, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
I cant install an operating system because immediately iswitch it on the dump memory screen appears
Turn the computer on, and press the DELETE key, to enter BIOS-setup.
Change the "boot-priority" to *FIRST* select the CD-drive.
Insert the Operating System into the CD-drive.
Save/Exit from BIOS setup.
The computer will boot from the CD-drive,
and start to reinstall Windows.
Nov 14, 2009 | Toshiba Satellite L305D-S5874 Laptop
How do i open the bios?
When you start you computer, you'll need to fit a key F1-F12 depending on your motherboard's model and you can access the bios. This F1-F12 number is usually displayed quickly before the motherboard boots off of the boot device, and it can likely be found in a reference manual
Jul 16, 2009 | Toshiba Satellite A65-S126 Notebook
Need to bypass password on toshiba t4850 laptop..??
well than don;t buy stolan laptops ! (if the case here !!!)
anyway, u;ll have to open it , and reset the BIOS ! (remove for a few seconds the small battery inside ) ... check for the computers manual ... all should be there ...
Dec 10, 2008 | Toshiba Satellite A100-S8111TD Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Jul 17, 2008 | IBM ThinkPad T21 Notebook
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 17, 2008 | Acer Aspire 3680 Laptop
HP Compaq NC6400 Business Notebook Logo
402 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
