Not premium stereo, so not a mach amp. Just stock.
Remote is generally blue out of the deck however if it is stock radio wire the amp remote to the accessory circuit on the back of sterio this will turn on the amp when your radio comes on instead of the radio turning on the amp there should be a memory wire that is hot all the time and a accessory wire that turns on the radio when the key is on
SOURCE: stock sub woofer quit working in my 04 ford
Here's a good place to search.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801ea557
SOURCE: where is the amp on a mach 460 system in a 2002
there are three amps. One is in the front in the dash board. The other two can be accessed through the trunk in the very back. You have to remove the two side panels first and then there are screws or some kind of bolts on the top of the back panel holding the back panel in place. Remove that you'll see in the center your motor to your convertible top and on the side your two amps.
if you have any questions just email me... [email protected]
good luck,
brandon
SOURCE: looking for 1996 ford mustang wiring diagram for stereo
things to consider:
Does it have a factory amplifier?
Is the factory harness still present?
Does it still have the speakers present?
You are going to only have a certain amount of wires... If the factory harness is still there you can simply purchase an aftermarket or just look at one in a local store on what wires are what.
you would have your:
gray and gray w/ black
purple and purple w/ black
green and green w/ black
white and white w/ black
these are normally used as an after market clip on harness for that factory wiring. (left front, right front, left rear, right rear)
Obviously your going to have the constant (yellow), ignition (red) and the ground (Black);
so the others would be either a remote (amp or power antenna) usually white with blue strip and dimmer normally orange for the after market harness, and the others will be the speakers.
What you COULD try is using a 9v battery and picking up the wires that are solid and striped and touching them to the 9v battery.
When you find the two that make that speaker make a popping sound you have found that speaker.
Once you have found the speaker that pops, you should be able to take it out and look at the color of the wires to make sure you will have the pos and neg for each speaker correctly set.
You dont want some speakers being in phase while other are out of phase. if so the sound wont be right.
SOURCE: wiring diagram/ amp hook up
without preamp outputs,you need to get a speaker line matching transformer.it takes the speaker signal,reduces the level,puts it thru a low pass filter if it is for a subwoofer. it basically is a tranformer resistor network that drives a set of rca plugs that will go into the amp. the only tricky part is noise,speaker lines have a poor signal noise ratio if you amplify them.
SOURCE: need wiring diagram for a 2002 mustang Mach 1
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
