Whirlpool Washing Machine, Product- F65, model7234,water overflow
Whirlpool Washing Machine, Product- F65, model-7234 , SL. No.-INB 034704402, customer code/ Equipment No. 4400435 purchased on 21-04-2004. Water is overflowing now, Complains made three times in this year for other problems one after another new problems are comming. How can I solve the problem permanently, Can you help me?
  • brsamadder Jan 01, 2009
    many thanks fr replying! but i donno which 1 is the water valve
    Sergeant:
  • 311 Answers
Top loader?usually its because your water valve is not closing because minerals have gotten into the water valve.but water would come into washer even when unpluged.another thing can be if when over flowing and u unplug it and it stops fillig/over flowing.your presure switch hose will have come off the water level switch or a mouse chewed a hole in it.its a clear tube thats running from your water level switch.i hope that helps god bless,tom
Posted on Jan 01, 2009
  • Thomas Malailua
    Thomas Malailua Jan 01, 2009
    the fill hoses are attached to it in the back,Tom
Whirlpool F65 PE Error?
F65 STEAMER TIME OUT REACHED Error
happens if there is no communication between Central Control Unit (CCU) and steamer electronic board. The failure will reset after running the Diagnostic Test Program. 1. Check connections between the Steamer Electronic board and CCU.
2. Check mains supply is in range (90V-132V).
Jan 03, 2015 | Whirlpool Washing Machines
Whirlpool LBR5232EQ2 Overflows on Medium Water Level Setting
This is the landlords machine that does this? There is a problem inside the machine with the water level sensor.
Dec 16, 2013 | Whirlpool Washing Machines
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
Cold water does not come into the machine and when washing the water keeps coming into the machine and the washer overflowed
bad fill vavle..it stuck open pull plug than replace the fill vavle....if you need help replacing vavle repost with model number ..good luck
Sep 10, 2011 | Whirlpool Washing Machines
My front loader washing machine shows F 9 on the digital screen which relates to water leakage. I have had this problem recitified previously, wherein water somehow leaked into the bottom of the machine,...
Sorry but Whirlpool 'F09' does state 'overflow'. It could be that the overflow sensor is being a bit keen i.e. malfunctioning, and needs a service call ;-0(
Sorry again,
John C
Apr 08, 2011 | Whirlpool Washing Machines
WHAT IS THE SIZE OF MY WHIRLPOOL WASHER? model number LXR9245EQ2
We have the same model. We plan to purchase a replacement washer, and tank size is a major factor.
Machine manuals are available at www.whirlpool.com. It's great Whirlpool has the docs available online, but there was no indication of tank volume for this model found in the manuals: Parts, User, Instructions.
I decided to figure it out by filling the washing machine tank manually counting the number gallons of water dumped in. I managed to dump in 23 gallons before risking overflow. I don't recommend this approach since the specified water level limit for the tank assembly may be lower than the perceived water level limit. This volume test was performed on a machine that's being disposed.
Google says 1 US gallon is equivalent to approximately 0.1337 cubic feet. Applying this ratio to the number of gallons poured in, the volume is 3.08 cubic feet. If 24 gallons, then 3.21 cubic feet.
I'm sure the tank is not 4.0 cubic feet since that would have required another 7 gallons of water, beyond the 23 already poured in, making a mess on the floor, and potentially wetting machine wiring and other hardware that should remain dry. Even if we account for the space occupied by the agitator, it's unlikely an additional 7 gallons of water could be added without significant overflow.
4.0 cubic feet is approximately 30 gallons.
We're going on the assumption our LXR9245EQ2 washer is a 3.2 CF machine.
Dec 07, 2009 | Whirlpool Washing Machines
Whirlpool washing machine F65
Filter is blocked where hose connects to machine or water valve faulty.
Sep 03, 2009 | Whirlpool Washing Machines
I hear some different noice along with slight vibration, when water filling in the washing machine. my washing machine model is Whirlpool F65 fully automatic one 2 one 2 wash. Its need any service?
Could the sound be described as a chatter / rapid clicking?
If so, it's probably the inlet valve for either the hot or cold water which is not opening all the way due to a dirty/malfunctioning solenoid valve.
Charlie
Aug 14, 2009 | Whirlpool Washing Machines
Washing Machines Logo
633 people viewed this question
Top Washing Machines Experts
