Question about JVC GZMG435AG Camcorder
We can't upload the recordings to our home computer.
Although the cable is connected from the camcorder to the home computer we can not upload.
The camcorder is a JVC Hard Disk Camcorder Everio.
The recordings that we want to upload are not saved to any hard disks... they were saved on the camcorder.
  • Taisha J
    Taisha J May 11, 2010
    Is there a error message being displayed? What is it?
    Novelist:
  • 166 Answers
Hi there,it seems u have not installed the software onto your computer. just install the software for your camcorder with the help of a CD that u might have recieved along with the it. then plug it through USB and its ready to transfer the videos.
good luck and do not forget to rate this solution.
thanks for using FixYa
Posted on Feb 11, 2009
How do I download a recording from my camcorder to my laptop?
Depending on the model of your camcorder, you should have or can get a cable to connect the camcorder to a computer. The procedure will depend on the model of your particular camcorder.
The computer may have to install drivers to recognize the camcorder and then will see it as an additional drive or mass storage unit. This assumes the camcorder isn't an older device with a removable disk of some sort.
You can then upload the data from the camcorder by navigating to the folder from the camcorder.
Some newer camcorders use "SD" cards that can be removed and inserted directly into a computer equipped with an SD slot or equipped with a universal card reader (usually a separate device)
Jul 23, 2015 | Computers & Internet
Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
PC Upload?
Here is the manual you can see online or download. You can put into a computer using a firewire.
http://www.scribd.com/doc/17476831/Cannon-MV500i-DV-Camera-Manual (IT SAY FOR A PAL - Not NTSC But everything should be the same, just a different way to record)
Canon DV Cable CV-150F (4-Pin to 4-Pin) for Canon Digital Camcorders
Sep 06, 2012 | Canon Video Cameras
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Hi HRU? Sir pls tell me how I can copy my Movies from Cam Coder of Sony DCR-HC28E in my pc although I have connect via usb cable to my computer but no any reply i foud. So pls guide me how I can?
This is the step-by-step for downloading from your camera as found on Sony's tutorial page:
  1. Turn on the computer.
  2. On the computer, install the USB driver for the digital camcorder. Note: Only the USB driver included on the supplied CDROM will properly enable the digital camcorder for USB streaming. Alternatively, you can download the USB driver here.
  3. Turn on the digital camcorder to the VTR, VCR or PLAYBACK mode.
  4. Turn on the USB streaming feature of the digital camcorder.
  5. Connect the USB cable to the digital camcorder.
  6. Connect the other end of the USB cable to the computer.
  7. Cue the video to the beginning of the video footage to be transferred.
  8. Start the video capture software on the computer.
  9. Begin playing the recorded video in the camcorder.
  10. Begin importing the recorded video with the capture software.
Dec 16, 2010 | Sony DCR-HC28E Camcorder
Can't link up to computer with usb cable. I want to upload...please advise.
please go to the camera setup option and change the output mode to USB....... connect the camera again to the computer and transfer your file ....
May 29, 2009 | JVC 32x Optical Zoom MiniDV Camcorder
I cannot upload my video from recorder to computer
take of the memorycard from camera and just put your sd-card to the memorycard slot and open it from my computer. and if you dont have one just connect camera to computer with cable
Jan 11, 2009 | Panasonic Palmcorder PV-DV103 Mini DV...
ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Nov 07, 2008 | Video Cameras
Uploading to computer
connect tothe computer with the firewire cable, plug your camcorder into the mains and open windows movie maker on your pc and press play on the camcorder and capture video in windows movie maker. Easy.
Nov 11, 2007 | JVC GR-D270US Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
JVC GZMG435AG Camcorder Logo
188 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
