Question about Linksys Wireless-G WRT54G Router
My router allows me to get on the internet via wireless but it will not alllow me to get on via a cable
    Problem Solver:
  • 7 Answers
Make sure you are using a good ethernet cable to start with. Next, when you connect your computer to the router (when the computer is on) do you see an indicator light underneath one of the port numbers on the front of the router light up? (1 ,2, 3, or 4?) - Is there a connection light on your computer where the other end of the cable is plugged in? If yes to these questions then... (assuming you're using windows) click 'start', 'run', then type 'cmd' and then hit enter (this brings up the command line (black dos screen) type 'netstat -rn' here, hit enter, and make sure your computers network interface has an IP of something like 192.168.x.x, or 10.x.x.x.. If it has anything else, then DHCP may not be working and your computer may not be getting an IP address from the router.
Posted on Jan 01, 2009
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
First time trying to connect to the internet through my wireless router. Do I need a cord attached to Dsi to wireless router to connect the two?
Basically you need to have your wireless router connected to the modem via a Ethernet cable this allows the signal to be received in another part of the house via wireless signals, after you have done this turn on your ps3 and go to network settings, click connect to internet then wireless network. After you have done this make sure you have all the security settings next to you if needed.
Jun 12, 2011 | Nintendo DSi Black Console
I just purchased a Acer Netbook 10.1 wireless. Do I need to enter a security code in order to get on the internet.
No, you do not need to enter a security code to get on the internet. You have to use an ethernet cable to connect the wireless router to your ADSL modem. Your wireless router should first be configured with an IP address that will allow it to communicate with the modem. However, if it works you should configure a security code on your wireless router to prevent others from connecting via your wireless without permission.
Feb 08, 2011 | Computers & Internet
I have a Xbox 360 Elite with a Xbox 360 Wireless N Networking Adapter attached. Whenever my son plays a game while connected to the home wireless network, no one else in the house can use the Internet...
If other devices can connect once your son is off then it might not be a problem with a router. Try connecting the xbox VIA WI-FI. If the problem persits i would contact your ISP.
May 22, 2017 | Microsoft Wireless Network Adapter Xbox...
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My netgear will not let me connect to the internet via my wireless connection my main computer has internet as it is connecter via the yellow cable to the netgear my other computers have a netgear adapter...
Open Zonealarm, choose Firewall, Zones.
Add >> IP Range set your IP range eg 192.168.0.1 to 192.168.0.254
This should allow connection between Router and Wireless Laptop/Desktop.
If your wireless PC cannot see the router, check your router setting to see if you are transmitting a SSID
May 18, 2009 | NetGear DG834G Router
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
ACCESSING MY LINKSYS
Hi Sorry for the late reply.
Do you have a phone number I could call you on?
Thank you!
-Cameron Bradford
Also, you can visit my website www.pc-fix.us
Aug 19, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
