Question about EA - Electronic Arts My Sims (Wii) for Nintendo Wii
It won't work!
When i put the disk in it starts making a funny sound, then tells me to take it out and turn it off. I do that and it still wont work. I know that it should work (right country) but it wont. HELP!!!!!!!
  • Anonymous Apr 19, 2009
    I put it in and it wont read it, cleaned it, still won't work. Kind of annoyed...
    Problem Solver:
  • 11 Answers
Have you checked the disk for any scratchs on it? that might be a primary source.
Posted on Feb 21, 2009
How to diagnose timing belt verses cam sensor wont start and sounds funny when turning over
If it sounds like it has no compression I would vote for the timing belt. Code 16 is for the cam and crank sensors being out of sync, and code 340 is no signal from the cam sensor. Which would happen if the cam is not turning.
Feb 10, 2014 | Cars & Trucks
2008 Nissan Quest Reverse Park aid stoped working. First sound got funny and then quit. The switch disable light stays on and won't turn back on
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
Sep 16, 2012 | 2008 Nissan Quest
Why won't my new bread maker turn on
hard to tell with out checking it out, a local repair shop should be able to tell. it sounds funny but slam it down on the counter, not hard enough to break anything but hard enough to jar it good. it could be that a brush is stuck from sitting most of the year. and double check that there are no safety features you may be overlooking. if that dosnt work the repair shop is going to be the answer.
Sep 01, 2012 | Applica Breadman TR520 2-pound Horizontal...
When i turned my emachine on it was making a funny noise and won't boot up
Sounds like your Hard Disk Drive is Bad and you will have to replace it this link will tell you how to install a hard drive
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Sep 08, 2011 | Acer eMachines 3502074 Netbook
Battery died,replace battery still no rotation on start , windows won,t come up sunroof inop.
i have the same car same problem. i found you can put your windows back up by using your car key outside of the car lock and hold the key in the lock position and your windows and sunroof will close. the next time you want to put your windows down put your key in the unlock position and hold and they will go down your sunroof probably still wont work but atleast your not burning up on a hot day in june. as far as your car not starting try turning your ingition HOLD it in the START position put your foot on the break and drop the trans. into neutral and it should start. i hope this helped and good luck with your windows i still havent got mine to work :/
Jun 03, 2010 | 1999 Volkswagen Passat
My daughter was on her laptop and it froze now wont work
it sounds like a hard disk has failed.
you will need a new one if this is the case and then reinstal the operating system. you can try take the hard disk out and put it in the freezer for a few hours then back in the laptop. if this makes it work save files want to a cd as this isnt a lond term fix
May 08, 2010 | Computers & Internet
My 1989 chevy camero, automatic, v8 305 engine, is acting funny. Brand new battery, water pump, brakes, tires, and trani mount. Has some wiring problems. Aparrently is wired backwards. It over heats alot....
CHECK YOUR CLUTCH COOLANT FAN IT SHOULD HAVE RESISTANCE WHEN YOU TURN IT WITH YOUR HAND.IF ITS LOOSE AND WOBBLEY.NEED REPLACING.THAT CAN CAUSE CAR TO OVERHEAT.ALSO IF YOU LIVE IN HOT CLIMATE.YOU NEED 50/50 ANTIFREEZE AND WATER.TOO MUCH WATER CAUSE ENGINE TO OVERHEAT.YOU NEED ANTIFREEZE MIXTURE TO RAISE BOILING POINT.TO HELP ENGINE COOL BETTER.NOW THE STARTING PROBLEMS.CLEAN BATTERY CABLES IF CORRODED.IF THEY ARE OLD BEEN ON CAR A WHILE REPLACE THEM.IF BATTERY CABLES IS GOOD. HAVE STARTER CHECKED REMOVE IT TAKE IT TO AUTO ZONE OR ADVANCE AUTO PARTS.SOUND LIKE A BAD STARTER HIT IT WITH HAMMER AND IT CRANK.
Sep 29, 2009 | 1989 Chevrolet Camaro
Yamaha dt 2003 wont start was working fine then ran out ov petrol then put more petrol in and 2stroke now wont start it started then was smoking bad for like 10 seconds then died now wont start at all btw...
sounds like you may have a air pocket in your fuel system. try cracking the fuel check on the bottom of the carb and make sure you have fuel. the only other thing i can think of is fouled plugs. I know it sounds funny on a 2 stroke but i have seen it happen
Jun 10, 2009 | 2004 Yamaha DT 125 R
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
My 52' vizio will not turn on
It's due for surgery to repair the power supply and or main board. One way or another it is defective but let's try the following couple steps as a work around (works for me)
Try this:
1- press power ON
2- wait 20 seconds
3- press power OFF
4- wait 20 seconds
5- press power ON.
Does it start the *second time* with the timings indicated above or never?
Feb 13, 2009 | Vizio L32 32 in. LCD HDTV
EA - Electronic Arts My Sims (Wii) for Nintendo Wii Logo
76 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
