Question about Car Audio & Video
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
    President:
  • 379 Answers
Http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Posted on Jan 01, 2009
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - was this information worth a FIX YA vote ? thanks for voting ! .
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Free wiring diagrams
google it my good man
Aug 25, 2014 | 1991 Subaru Legacy
1999 subaru legacy b4 engine hesitation
try wires the wires usually does that..also ride to autozone like i did and get a diagonostic and theyll tell u which cylinder is misfiring
Nov 16, 2012 | 1999 Subaru Legacy
Subaru Liberty Engine check light has come on, has a EJ20TT from a 94 Legacy. Just wanting to find out how to check engine trouble codes through the diagnostic port, (which wire would i need to plug into...
Your model and year has OBDII. I would not suggest shorting any wires. It will not flash codes. Most Auto parts stores will test it for free. Good luck and have a great day.
May 03, 2010 | 1997 Subaru Legacy
Re-installing a twin turbo boxer engine into a 94
CHECK OUT AUTOZONE.COM FOR BOTH OF THOSE ITEMS, JOIN UP_its free and safe_AND YOU CAN DOWNLOAD THE REPAIR GUIDE FOR THIS CAR WITH DIAGRAMS.....
Mar 08, 2010 | 1995 Subaru Legacy
1990 subaru liberty.. whats code 14
do you mean a legacy? on a legacy a code 14 means the injector for cylinder #1 is not operating
Feb 25, 2010 | 1990 Subaru Legacy
Wiring diagram for 2001 subaru legacy
Hello, this diagram is not for the Mcintosh system. If you need the Mcintosh system just let me know. I hope this info helps...(subytech1)...
Jun 04, 2009 | 2001 Subaru Legacy
1994 Subaru Legacy has intermittent starting problems
Sounds like wiring. Start under dash for loose or dirty connections. THen check starter wires main hot wire and especially the ground wire. Hope this helps and have a good day.
Apr 12, 2009 | 1994 Subaru Legacy Outdoor
Electric vs manual
Yes you can do this, most cars have one wiring harness for all models, so the connectors are most likely already there, but you will need a fair amount of electrical knowledge to pull this off.
Oct 02, 2008 | 1997 Subaru Legacy
Car Audio & Video Logo
162 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
