Question about HP Compaq Presario v3000z Notebook
Bios says no ide device found (hard frive missing?)
Computer worked fine 2 days ago then turned it on and it stopped at the compaq logo. down at bottom left of screen gave choice of boot order or f10. per Hp tech have reseated memory, re-seated harddrive, drained battery and set bios to default. When i do a hard drive test in bios is says ide device not detected. Tech person said to send puter in for them to check. said will cost 298.00. Economy sad don't have that kind of money. Any other help? Running windows vista. Came with ie but upgrated to vista a year ago- working fine since until 2 nights ago. If let it sit at logo icon it finally goes to blank screen with blinking curser in upper left but won't go any further. PLease, PLease help. Can't get into safemode by tapping f8. Am ready to pull out hair.
    Scholar:
  • 55 Answers
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Posted on Jan 01, 2009
2 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: Compaq Presario C304NR STOPS LOADING AT COMPAQ LOGO
It sounds like the hdd has failed. When you try to boot can you hear the hdd attempting to spin up? Best solution if everything else checked out would be to replace the hdd. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 31, 2008
How do I go into bios to make my primary 1 hard drive found
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or f2 key this will vary depending on your operating system and computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps.
Nov 25, 2012 | Computers & Internet
How to master rester a compaq presario sr2150nx
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
??????????????????????????????????????????? hope this helps
Dec 29, 2010 | HP Compaq Presario SR2150NX PC Desktop
It tries to boot from the empty diskette drive and I can not change the BIOS booting sequence
hope this helps
Dec 03, 2010 | HP (158800-001) for Compaq Presario 1246,...
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
I have a compac computer with uwave motherboard it says it cant find hard drive whenteyin to turn on
First open cpu cabinet.
Then disconnect power cable and sata or ide cable from harddiks then connect agagin.
Also check your ide or sata cable which connect to hdd works fine.
Refix your RAM memory to.
Then when you power up the computer press F! or F2 or "del" key to enter in bios.
Then check in bios that your hdd is detected?
Then if detected set first boot device in boot optionj in hdd then check.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Compaq Presario 5000 PC Desktop
I ran into a emachine desktop 3 days ago, and reinstalled operating system, everything was working fine, however when i shut down and booted the next day, computer continued to reboot itself after passing...
there is usually a jumper with three pins beside the cmoss battery just move the jumper to the last two pins for 5 seconds and put it back that will reset your bios that may help
Apr 18, 2009 | Computers & Internet
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
Dec 31, 2008 | HP Compaq Presario v3000z Notebook
Ml530
There are many configuration settings, although i personally would hunt down an SCSI hard disk, many will fit from many other models just like IDE ones
Mar 24, 2008 | Compaq ProLiant ML530 Server
Before boot menu problem
Lets check & see if your hard drive is still bootable before doing anything else. As soon as you turn on the PC start pressing the F8 key every 2 seconds on the keyboard. A Boot menue will come up. Choose your hard drive by moving the up or down arrow keys. than press enter. You should see other bootable devices like, Floppy (if you have one connected), CDROM & Hard drive. Still stuck with the blinking line? Every computer uses a differant F key to enter the Bios. Your's can be F1, F10 or F12. Just like the you did with the F8 key restart & try each untill you enter the Bios. It will help you a bunch if you have your manual that came with the PC. When you get into the Bios it will load at the main menue. You'll know this because you can set your time in this window. You will not be able to use your mouse just your keyboard. At the bottom of the screen is instructions on how to move around in the Bios. In this Main screen your looking for your hard drive. It should be listed somethink like IDE Primary Master and its nameed like "ST3250NV". Thats an exzample name. Your will be differant. Listed under the primary Master will be Primary Slave. Under that will be Secondary Master than Secondary Slave. One of the Secondary devices will list your CDROM. If you do not see anything listed for the Primary Master than your drive is faulty. The link below shows what is inside of your Presario 4090US.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00009310&lc=en&cc=us&dlc=en&product=92635&lang=en
You will need a new IDE hard drive.
Jan 31, 2008 | Compaq Presario 4090US (470016-303) PC...
HP Compaq Presario v3000z Notebook Logo
3,696 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
