Question about Compaq Amarda M700 Notebook
Registry question Ok i just downloaded the regcure because you said i might have a problem with the registry. how do i get my computer to go to safe mode when it wont in order to run program>
  • delilahxxzz Jan 01, 2009
    when I tried to put it in safe mode, it just goes back to lue screen? now what???
  • kdreis May 11, 2010
    on the startup screen after you start the computer hit f8 and it will go into a DOS mode scroll to safe mode and hit enter
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
Spped up your PC registry
<span>More seriously, these errors could cause the crippling of your Pc In the event you don't resolve these difficulties. Yet another cause could be that there was a dll that was shared by many applications as well as the reference was placed on the When you have more programs installed in your pc then it may become slow, to fast up your pc use this Regcure application. Regcure software Reviews is a software to clean up the registry of your computer. Guidelines On Making Your Computer Quicker. Published June 3, 2011 ' By Icabod Lucas Xavier. If you feel that your computer has been running slower and slower lately, then you've come to the right place. Many people believe in something called "processor If you don't mind paying for a solution, you can some utility software that will both remove all the <span>spyware and adware</span> from your computer as well as clean up your registry. That way you'll get the fastest computer A lot of the time a simple reboot or removal of new hardware will resolve this issue and the computer will be back up and running. In the event that it is a bit more complicated then the computer will not load and the only way in is safe mode. Austin Porter managed to fix all his PC's errors by downloading a top Registry Cleaner!</span> <span><br /></span> <span>Download it from here--</span><a href=""></a> <br /> thanks for rating
on Jun 03, 2011 | Computers & Internet
How to Erase RegCure from your pc system
<span><span> <p>RegCure is a registry repair tool that allows you to solve registry errors, such as missing dll files, damaged registry keys and corrupt settings. If you are no longer interested in this program, or prefer to install and use a different registry repair tool, uninstall RegCure from your<span> </span><a href="">computer</a>. Uninstalling RegCure is a quick and simple process for Windows 7, Vista and XP users.<span></span><br /><br /><span></span> <span>Instructions</span> <ol> <li> <ul> <li><span>1</span> <p>Click the "Start" menu and then click "Control Panel." Click "Uninstall a Program" if you are using Windows 7 or "Programs and Features" if you are using Vista. Double-click "Add or Remove Programs" if you are using Windows XP. The programs window will launch.<br /></li> <li><span>2</span> <p>Scroll down and click "RegCure." Click the "Remove" or "Uninstall" button. If prompted, enter your administrator password and confirm you want to remove the application. The setup wizard will remove the program.<br /></li> <li><span>3</span> <p>Restart your computer to complete the process<br /></li></ul></li></ol></span></span>
on Dec 27, 2010 | Computers & Internet
My wife just replaced the launcher icon on her home screen with her messages icon is there anyway to fix this. She cannot get to her apps
Problem is with registry in registry system of computer Operational System .
You have two solutions:
1. Put again new launcher or
2. Download application RegCure and fix the problem
Feb 26, 2011 | Computers & Internet
Physical memory dump at working this error comes after 5 to 7minuts latter when system starts please help
When someone receives the error message,
“Physical memory dump ", usually accompanied with a blue screen. Chances are there is a possible problem with your memory. Before you download memory testing software, let’s try downloading some free software. RegCure is free to download.
RegCure will clean windows registry. It will safely remove problem keys.
If RegCure doesn't fix the error message try the next link;
Lastly, download & run Memtest86+ at this link;
Scroll down until you see the 3 screenshots. Choose the testing software to create a bootable floppy disk. This software will test your system memory. If Memtest86 finds a problem you will need to replace the problem memory stick.
Read each site & follow their instructions.
Thank you for using Fixya.
Download - Pre-Compiled package for Floppy (DOS - Win)
Aug 25, 2009 | Computers & Internet
Has anyone ever download a software called RegCure
I have used it, but didn't find it very effective. Free software is safe to download if it is from a reliable source, so always be sure.
I would reccomend you download ccleaner. Its completly free, and very effective.
Jun 26, 2009 | Computers & Internet
Lexmark 6200 Series Center won't open
Hi John, doing a reinstall is not advised unless you completely remove the software first. (Power off the printer).
Try removing all software for the 6200. Once all of the software has been removed restart the system. Check if the 6200 is still listed in, Printers and Faxes. (If it is listed delete it). Than download & install RegCure, which is a free program that will clean windows registry from all none needed keys. Download RegCure from this link:
Restart your system when RegCure has finished.
Now you can safely reinstall your printer software.
Good luck John!
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>>
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM
Oct 24, 2008 | Microsoft Windows XP Home Edition
Product Key for Active @ Undelete
RegCure™ (from ParetoLogic®) provides fast and efficient scanning and cleaning of your registry so that your computer can run at an optimal level of performance. RegCure identifies invalid registry items and you decide what items you want to remove. After removing registry entries, you have the option to restore your computer to a previous state.
Protect your investment and ensure maximum PC speed and performance with RegCure registry cleaner. Compatible with all Micro$oft products and third party applications, RegCure seeks out and repairs those issues in your registry that lead to poor performance such as remnants left behind on your registry from failed installations, incomplete un-installations, disabled drivers, and spyware applications.
RegCure enables you to fix your PC's windows registry in the way that is most comfortable for you. Clean your registry manually according to your own specifications or perform a thorough scan and clean it automatically!
The user-friendly interface allows you to monitor the progress of your scan, schedule RegCure to scan at the times that are best for you and will even manage and clean up your start up programs for you if you wish.
Dec 05, 2007 | Computers & Internet
Tech com driver
Try right clicking to the My Computer icon on your desktop. scroll down to properties, and then select the hardware tab. The choose device manager and scroll down until you see the webcam and then choose to update the driver. If there is a more current one out there then the updating will generally find it for u.
Nov 29, 2007 | ABS Computer Technologies Awesome 1300...
Compaq Amarda M700 Notebook Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
