Question about Toshiba 50HP66 50 in. Plasma Television
Blue line down center of tv
My new sony flatscreen tv has a 2 inch wide blue line going down the center of the screen..what is causing this?
HDTV GURU
  • 261 Answers
SOURCE: 42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Posted on Mar 16, 2008
SOURCE: 40 inch lcd blue line vertical
Have just purchased Samsung LA32R81BD have thin blue vertical line a third into the left hand side of the screen. A pity no support on a sunday or public holiday! Tried the squeeze theory without joy. Will attempt swap and see what excuses the dealer has? Thanx for advice fixya!
Posted on May 03, 2008
SOURCE: black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Posted on Mar 13, 2009
  • 1587 Answers
SOURCE: thin blue line down middle of screen
The red line driver at that point isn't working or there is a bad connection to the panel for that line. (I assume the intensity and hue of the cyan line varies witht the picture). What type of screen is it? Plasma or LCD? The following is for LCDs and may not apply to plasma panels. (I haven't had to fix those yet.)
Once in a while you can solve the problem on an LCD by gently massaging the connector to the display panel edge at the bad spot, although there is a risk of causing other lines to drop out. I once fixed an LCD that had a hair caught between the elastomeric connector and the display glass, but if that were the culprit in your case, you'd probably be missing more than one line. It could also be a problem with the driver chip for that line.
Be very careful about tearing into the LCD. The connections are very delicate, the fluorescent backlight tubes are glass and have mercury inside, and the potential for electrostatic discharge damage is always a concern. It's easy to cause more problems than you fix when you get into the connections, although those can usually be reversed with patience and steady hands. The worst case is a misalignment that would mess up your color registration (color drive going to the wrong line). Most panels have a sticker inside warning against removing the driver electronics. It's there for a good reason.
If I've scared you off, or if the connector massage doesn't work, there are companies like Moniserv that specialize in repairing LCDs. They have the equipment and dust-free facilities needed to repair bad panel drivers.
Posted on Mar 23, 2009
circuitworld
  • 335 Answers
SOURCE: black line half way down the center of the screen,about 1.5 inche
There's a 'data control' and/or 'address' problem that's developed. Pixels depend on voltage, control, and data coming too their designated address.
A digital circuit feature called a 'DATA_ADDRESS_ BUS" are responsible for 3 criteria: Delivering voltage, control, and data to each pixel in less than a second.
1) If voltage fails the pixels don't light up. They appear black in color (their 'off 'state)....numerous pixels that don't light up look like a black line. But their actually individual pixels with no voltage.
2) If control fails then all pixels are white in color (their 'on' state). Without control the pixels can't adjust properly to high or low 'state', meaning brightness and dimness. This looks like a white line vertically on the screen.
3) If data fails then the pixels can't adjust to the proper color at the proper time.
This appears as a line that changes color out of sync with the entire picture.
Have a technician look at the pixel address registry circuits. As well as control and linear circuits....the problem is somewhere in there!
Posted on Jun 13, 2009
Sony lcd TV model kdl-46ex701 vertical colored lines on screen
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 10, 2015 | Sony Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Hitachi digital ultravision 50"
Hello bugster421,
Can you post a picture of this problem? It will go a long way in determining what is happening.
Thank you,
Shuttle83
Oct 26, 2007 | Sony KP-46WT500 46" Rear Projection...
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 03, 2014 | Televison & Video
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Nov 14, 2009 | Televison & Video
54" Sony Wega made a loud popping sound and now has Black lines
When I got my new LCD big screen, it had a black line across the entire width. It looked like the screen was pinched.
They claim that it can be repaired but that repair costs as much as a new tv.
My tv was replaced. Hopefully your warranty is still in place to get the unit replaced.
Mar 26, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Toshiba 50HP66 50 in. Plasma Television Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
